86' Ty350 Resto?!
jas
Here I go again, trying to talk myself into or out of another motorcycle restoration. I've already started on the engine and I had been debating on keeping it as a "spare" but I have the frame it came out of.... So toying with the idea of jumping in on another one. Any words of encouragement or discouragement would be appreciated.
I am missing the following parts:
Fuel tank, seat, front wheel, front axel, and the brake light switch.
 I once used the front wheel, master cylinder and caliper from an `84 YZ125. It all bolted straight  on, except  a machinist made a bracket from the caliper to the fork that was just held on with hose clamps. Covered it up with a disc cover. Actually was a great working brake. Since you have a few TY`s, this might be an easier fix.
Hmmmm, that might be the way to go! This should probably be a custom build rather than a restoration....
Anyone have p/n's for the caged rollers and steel bushings for the swing arm? Also need p/n's for the shock assembly bushings.
Thanks in advance.
  • 3 weeks later...
  On 10/16/2015 at 8:54 PM, jas said:
Well.... Restoration on hold now, I just bought another 85 so.... 3 running TY350's is enough for now!
That didn't last long..... Decided to part out the last 85 and move forward withe the 86 build. It'll be a different bike than my other two.....
Parting this one out...
Frame ready to go to the powder coater..... It will be black.
