bobtail Posted October 15, 2015 Report Share Posted October 15, 2015 Does Anybody know if there is another brand of trials bike front wheel apart from a montesa that will fit a 2015 4rt regards . Quote Link to comment Share on other sites More sharing options...
bullylover Posted October 16, 2015 Report Share Posted October 16, 2015 A friend on mine has just bolted a late Gas Gas rear wheel to his 2015 4rt using one Montesa spacer and one Gas Gas one. They do fit. Graham. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted October 16, 2015 Report Share Posted October 16, 2015 I have had an early 315 wheel in one and now have a 2000? sherco as a 3rd spare for marking out and practice etc. Just need to check spacing required to get disc in centre of calliper. I have found a wheel bearing centre race works well as a spacer. Early wheel may have larger/thicker disc but if the wheel is cheap enough £40 on suitable disc is still worth it. Most front ends run similar set ups as forks are common across most bikes. Quote Link to comment Share on other sites More sharing options...
bobtail Posted October 16, 2015 Author Report Share Posted October 16, 2015 Thanks for replys will visit for sale section Quote Link to comment Share on other sites More sharing options...
collyolly Posted October 17, 2015 Report Share Posted October 17, 2015 Not sure most front ends are the same, Gasgas use the fat spindle so bearings may differ to the Honda, these may not have the same outside diameter so the hubs may not be convertible. Rears are more likely to be an easy conversion as I think most bikes use the same size rear spindle. Check this out before you invest in a wheel. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted October 17, 2015 Report Share Posted October 17, 2015 As I happen to have one on the desk in front of me I can tell you that the 4RT front spindle is 20mm diameter. Quote Link to comment Share on other sites More sharing options...
