Spare Wheel
bobtail
I have had an early 315 wheel in one and now have a 2000? sherco as a 3rd spare for marking out and practice etc. Just need to check spacing required to get disc in centre of calliper. I have found a wheel bearing centre race works well as a spacer. Early wheel may have larger/thicker disc but if the wheel is cheap enough £40 on suitable disc is still worth it.
Most front ends run similar set ups as forks are common across most bikes.
Not sure most front ends are the same, Gasgas use the fat spindle so bearings may differ to the Honda, these may not have the same outside diameter so the hubs may not be convertible.
Rears are more likely to be an easy conversion as I think most bikes use the same size rear spindle.
Check this out before you invest in a wheel.
