sprite125cc Posted October 24, 2015 Report Share Posted October 24, 2015 hi I understand that the condenser can get too hot .can it be moved and if so how and to where?many thanks. Quote Link to comment Share on other sites More sharing options...
nh014 Posted October 24, 2015 Report Share Posted October 24, 2015 Common practice on Montesa's is to disconnect the stock unit in the backing plate. Purchase any good automotive condenser and mount and ground it between the frame reinforcements in the headstock. Splice the condenser wire to the hot wire from the coil. No more heat failures or pitted points. Quote Link to comment Share on other sites More sharing options...
sprite125cc Posted October 24, 2015 Author Report Share Posted October 24, 2015 What do class as the hot wire from the coil thanks again. Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted October 24, 2015 Report Share Posted October 24, 2015 Take a look here: http://montesakingscorpion.blogspot.com.es/2015/09/una-de-moto-revue-y-otra-de.html It's written in spanish, but I hope the pics are clear. I use modern electronic condensers that cost around 0,5 euros. Quote Link to comment Share on other sites More sharing options...
