Bad Coil?
squid_on_a_300
Ok...get this...a little over 1 year ago at a trial with a long loop my 03 300 Pro was acting up..Near the end of the 1st loop it started to sound kind of "dull" then wouldnt take any throttle, bogged out like it ran out of gas and it would not start.  I pulled the plug and it was a nice light brown and dry...Figured i had a fuel problem somewhere.  DNF'd the event packed up and drove home.  Cleaned the entire fuel system. Bike started up and ran great since...Today at the same event, going between the SAME TWO SECTIONS as 1 year ago, the bike did the same exact thing.  Deja vu all over again!...Pushed it back to the truck yanked the plug.  Nice and tan and dry. Checked for spark...very weak and only on about every other or every third rotation.  Got home, checked for spark..nice blue spark.  Put the plug in and the bike started right up....
Likely culprit, HT coil or pick up coil?...Im figuring the HT but how can I bench test the HT coil for failure when hot?
2003  300 pro with Kokusan ignition...
thanks in advance
Squid...
You can't properly bench test a HT coil without proper gear. Warm your bike up at an Auto diagnostics centre and they will be able to check the coil with a clip on tester in a few seconds. Its just a matter of clipping a sensor onto the HT lead or holding a COP probe against the coil.
Lineaway
I thought the same thing...I told one of the guys that I'll check at that event next year!
I thought again a fuel issue but the weak spark points to the coil?
I'll spring a $100.00 for a new one and see if that thakes care of the issue next year...
Edited by squid_on_a_300
