fantic tom Posted October 26, 2015 Report Share Posted October 26, 2015 After playing out the other day I washed my fantic and now it won't start! It's had a few days to dry any ideas? Cheers! Tom. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted October 26, 2015 Report Share Posted October 26, 2015 Kill switch? See if the spark plug fires? Quote Link to comment Share on other sites More sharing options...
wakka Posted October 26, 2015 Report Share Posted October 26, 2015 check inside plug cap as well if its old ,I use electrical clear grease works a treat, make the cap pull off so much better Quote Link to comment Share on other sites More sharing options...
fantic tom Posted October 27, 2015 Author Report Share Posted October 27, 2015 not had time to take plug out but had a few kicks on it today and it kept nearly firing, iv got a feeling its the kill switch and it is is drying out. ill avoid that area next time Quote Link to comment Share on other sites More sharing options...
maggar Posted October 29, 2015 Report Share Posted October 29, 2015 You didn't bung the silencer when you washed it and have left it in? Quote Link to comment Share on other sites More sharing options...
fantic tom Posted October 29, 2015 Author Report Share Posted October 29, 2015 You didn't bung the silencer when you washed it and have left it in? hi magger no i didn't bung the exhaust Quote Link to comment Share on other sites More sharing options...
fantic tom Posted October 29, 2015 Author Report Share Posted October 29, 2015 still not starting! the plug is dry inside too. is there any way to bypass the kill switch? Quote Link to comment Share on other sites More sharing options...
smokey125 Posted October 30, 2015 Report Share Posted October 30, 2015 Depends on how your ignition is setup. If the kill switch is a make contact to kill the engine just unplug it. This is how my 309 is setup. If it's a break contact to kill then you need to unplug the switch and fit a jumper wire between the terminals on the loom. Dry plug sounds more like a fuel problem to me. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted October 30, 2015 Report Share Posted October 30, 2015 The Fantic kill button as standard earths to the bars. Just take it off the bars but make sure it is well clear when you then try to start the bike. Quote Link to comment Share on other sites More sharing options...
fantic tom Posted November 8, 2015 Author Report Share Posted November 8, 2015 Well still no luck! It run out of fuel just before this happened too do you think this could be related? Should it just be a case of filling it up and it should start? Quote Link to comment Share on other sites More sharing options...
smokey125 Posted November 9, 2015 Report Share Posted November 9, 2015 When you said the plug was dry I thought it sounded more like a fuel problem. Some more fuel might sort it. It could be that in the washing process you've accidentally got some dirt of water or both in the carb. I'd start with fuel and if that doesn't fix it take the carb off and give it a good clean out. Quote Link to comment Share on other sites More sharing options...
fantic tom Posted November 11, 2015 Author Report Share Posted November 11, 2015 When you said the plug was dry I thought it sounded more like a fuel problem. Some more fuel might sort it. It could be that in the washing process you've accidentally got some dirt of water or both in the carb. I'd start with fuel and if that doesn't fix it take the carb off and give it a good clean out. Cheers I'll have a look soon and update. Thank you! Quote Link to comment Share on other sites More sharing options...
fantic tom Posted November 18, 2015 Author Report Share Posted November 18, 2015 well I removed and stripped the carb and it was spotless, when I put it back together it fired perfect and run for 5 seconds and as I tried revving it it made borping noises and died - it was running on carb cleaner fumes! This shows its sparking ok so must be as sparky125 suggested it sounds as if it definitely is a fuelling issue? im stumped now, any ideas what it could be? Quote Link to comment Share on other sites More sharing options...
smokey125 Posted November 19, 2015 Report Share Posted November 19, 2015 I would start with the basics. Is fuel getting to the carb? Check the fuel tap, disconnect the fuel pipe form the carb hold the end over a bowl and turn the tap on. Does fuel come out? If not check the pipe and the fuel tap itself. There may well be a filter on the tap inside the tank this could be blocked. If fuel is coming out the pipe at a good rate then check the float bowl again. Is the float working properly, or is it sticking. You need to start at the beginning, the tank and work from there until you find where the fuel is not getting to. 1 Quote Link to comment Share on other sites More sharing options...
laird387 Posted November 21, 2015 Report Share Posted November 21, 2015 After playing out the other day I washed my fantic and now it won't start! It's had a few days to dry any ideas? Cheers! Tom. Nobody has asked the obvious - was a power washer involved????????? Useful devices for forcing grit into wheel bearings and water into places never intended to get wet............... Quote Link to comment Share on other sites More sharing options...
