Point Gap, Ty80
jas
15 to 18 thousandths of an inch or about 0.4mm. I don't think you can move the stator backplate on a TY 80 and therefore the timing (in addition to dwell angle) is fixed by points gap. Smaller gap retards timing, larger gap advances it. If you can find the specified advance / TDC then use a strobe to set this. I think TY 80 should be set between 1.8 and 2.3 BTDC.
