mirko91 Posted November 7, 2015 Report Share Posted November 7, 2015 Hello, just bought a few months ago a GG280 2005 from an hunter which he was using to ride around the forest. The number of hours it has on it it's sadly unknown and after changing piston, clutch, rebuilding the suspensions and the linkage and countless money I blew it has a strong Vibration when I cleanout the engine. This happens when the revs go up and at a certain rotation it starts vibrating like mad. All screws are nice and tightened and I'm thinking about crankshaft bearings or even unbalanced crankshaft. Any thoughts? Cheers Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 7, 2015 Report Share Posted November 7, 2015 Take the flywheel cover off and grab the rotor to feel for any up and down play. Quote Link to comment Share on other sites More sharing options...
mirko91 Posted November 7, 2015 Author Report Share Posted November 7, 2015 On 11/7/2015 at 5:28 PM, lineaway said: Take the flywheel cover off and grab the rotor to feel for any up and down play. Thanks I'll do it tomorrow, that will assess if the bearings have play and so are gone Quote Link to comment Share on other sites More sharing options...
mirko91 Posted November 8, 2015 Author Report Share Posted November 8, 2015 Well, just tried to rock up and down the flywheel with cold and hot engine but had no chance to feel any minimal amount of play..same was for the conrod when I changed the piston and little end bearing, all mint Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 8, 2015 Report Share Posted November 8, 2015 Another common issue on the pro is the kick start pawl. It chips easily and gets carried by the idler gear to the large primary gear. (The teeth on the clutch)It does not take much metal to cause a vibration or knock. It can be very hard to find. (magnify glass needed) It gets smashed between the teeth to the point that it looks normal to the naked eye. Good luck. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted November 8, 2015 Report Share Posted November 8, 2015 But that should probably also be hearable when not reving it (high). Not a carb problem on high revs? Quote Link to comment Share on other sites More sharing options...
mirko91 Posted November 8, 2015 Author Report Share Posted November 8, 2015 On 11/8/2015 at 6:31 PM, crazybond700 said: But that should probably also be hearable when not reving it (high). Not a carb problem on high revs? Well it doesn't make any rumbling noise or anything, carburetion wise it is spot on ab tad reach on the low side but than it is perfect. Maybe the crankshaft shoulders are misaligned? Quote Link to comment Share on other sites More sharing options...
huski Posted November 8, 2015 Report Share Posted November 8, 2015 Can you Post a video so we can hear it?Hard to describe a noise/vibration accurately Quote Link to comment Share on other sites More sharing options...
baldilocks Posted November 8, 2015 Report Share Posted November 8, 2015 Petrol tank buzzing on the frame. It should have a foam strip on the underside of the tank where it rests on the frame. If not that the head steady bracket from cylinder to frame or an engine bolt is loose Quote Link to comment Share on other sites More sharing options...
aussiechris Posted November 9, 2015 Report Share Posted November 9, 2015 Yeah, check the front fuel tank bolt and also the exhaust mounting bolts. And, of course, engine mounting bolts. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted November 9, 2015 Report Share Posted November 9, 2015 Good suggestions yes Quote Link to comment Share on other sites More sharing options...
mirko91 Posted November 10, 2015 Author Report Share Posted November 10, 2015 I will check it all tonight. Thanks Quote Link to comment Share on other sites More sharing options...
