92 Synt - Primary Gear Nut Loose
mayday
So, new member, new to me bike (loving it!) - bit of a back story - gear up to go for a ride, kick it over, and she proceeds to SCREAM full RPM (turns out the throtttle slide wasn't seating fully) - of course my kill switch chose that moment to stick, so took a few minutes to get the fuel turned off, bike finally dies.
After teaching the neighbourhood children a few new curse words, got things sorted out, but when I tried to re-fire it, kicking it was as if there was no compression - turned over way too easily.
Took it apart and found what I think is the problem - the primary gear nut was loose, and the locking washer bent out.
So, my question to the masses, since I've searched to no avail for a shop manual for this bike - I'm guessing I should be able to re-torque the nut (120N/m), new lock washer, new case gasket (assuming I can find those) and Bobs Your Uncle?
Anything else I should be looking for/doing  while I've got it open?
Well, this process has been informative if nothing else!
Just an FYI for anyone else who goes through this - nope, no key - after pulling the clutch basket, then primary gear off, found it's a tapered shaft. Let's see what happens when I put it all back together.
Have you found out why there is no compression, the lack of flywheel should not stop your compression.
Take out the plug and turn the engine over by hand with your finger tip over the plug hole to make sure there is something going on in the top end.
Montesa Cota 247, 348 and 349 also drive the primary gear with a taper
No, the OTHER side of the bike :-)
When you push on the kick starter, it pushes on a small gear, that pushes on a larger gear attached to the clutch basket, which finally pushes on a medium gear which with the taper fit, turns the crank. So when I finally tightened that nut, the piston goes up/down.
Unfortunately since I went searching for a key that wasn't there, I ended up having to take off the clutch basket - and since I'm a degenerate "don't want to buy any specialty tool I can't Redneck something I already have to use instead" - I now have to buy a whole new clutch basket, as my Redneck clutch basket Holder" only ended up breaking off a tang on the outer basket :-(
I have been there before...............with similar results.
As a late teen/early 20's I used a pry bar to hold an S-10 (small truck) serpentine belt tension pulley back.  Promptly snapping the arm of the tensioner off.  When buying new one at the dealer ($$$$$$$$$$) found out there is  a little square inset in the arm that a ratchet/breaker bar would fit into and then pull back on the arm without breaking it........................... :wall:
