Advice On Snail Cam
neilboxer
The already mentioned measure of the distance between the axle of the swing arm to the axle of the axle of the wheel is in my experience the best way to find out if the wheel axle sits' right. For the chain alignment there are little laser units available with the laser sot you can measure the distance between the dot and the sprockets which should be the same.
To the snails: At some models the side with the threat in the axle is smaller in diameter so you need to spin the snail a little bit longer to position the axle right?
