2016 Sherco 300 Mixture
ady witting
The Kiehin is a fairly sensitive carb, thus there is no "perfect " setting as it will vary on the day based upon temps, baro and such.
Normal range between 1/2 and 1.5 turns out. Set for best idle and response off idle. Colder days require less air(screw "in")due to higher air density for a given jet size.
About 1/8 turn on the screw can make a difference.
A good ear helps!
Edited by copemech
Hi i was just wonder what is you opinion on the new sherco and what is the 300 like ive tried to 250. I am worried about getting 250 as i think it wouldnt be powerful enought as a 300 would be easy to get up very steep mounds. I ride a 2011 290 sherco and i think the power is great many thanks
