2000/2001 Txt 250 Dreaded Engine Troubles!
alscott1984
I have known the item that causes this type of damage to be bits of piston ring, rivets from the main bearing cages or pieces of big end cage.
Edit - the barrel looks as if it will be OK, just needs a good clean up and check there is no more bits about to break off.
Edited by dadof2
