Wheel Bearing Spinning In The Hub. . .
lockie28
hi.
iv just ordered new wheel bearings(6004) for my rev3 2004.. bearings arrived and in one side of the wheel the bearing is loose on the hub ( does not need tapped in )
anyone encountered this problem before and is there a quick fix for sealing it in there.
cheers
hi.
cheers
hi , depeding on how bad the hub is , you could either use bearing fit , made by locktite or similar . or if really excessive clearance , you may have to get hub machined and fit a sleeve or find a secondhand hub/wheel . hope this helps .
Could try driving a centre punch into the hub surface at several points where the bearing fits. This raises some of the metal above the surface level giving the bearing something to engage with. Do this along with using Loctite if you wish, or try on its own to start with. Worked for me decades ago with a Bultaco.
You could use a punch and put several divots all the way around. Don`t laugh, Sherco put out a service bulletin using this technique to solve the main bearings spinning in the center cases! It works!
Clean or bust beat me to it!
Edited by lineaway
Before you start knocking on the hub try another bearing. It is always possible that you have got an undersized one. With the amount of counterfeit rubbish coming in from China and other far eastern country's it's worth double checking.  I have even had bearings from a reputable suppler that were listed and packaged as SKF turn out to be forged rubbish.
