Mapping Switch
trialsash965
Normally you would pick the map you like then check if the switch is shorted or open circuit using a multimeter.  Then simply disconnect and remove the switch.  If your preferred position is with the switch in the open circuit condition then just leave the wires on the wiring loom disconnected.  If your preference is with the switch closed (shorted) then you will need to connect the two wires in the wiring loom together.
Chris.
