pudrev3 Posted December 3, 2015 Report Share Posted December 3, 2015 Hey guys this is strange , I have a beta Evo 4t , my fan hasn't been coming on last Sunday so I started it up and waited a couple of minutes and it still didn't come on so I removed the waterpump and there is no impeller there just the circlip!! Where has it gone and will it have done it damage , please say no it hasnt Quote Link to comment Share on other sites More sharing options...
iridebikes Posted December 3, 2015 Report Share Posted December 3, 2015 Some of the bikes haven't got one on from the factory, just put one on and should be fine Quote Link to comment Share on other sites More sharing options...
johnnyboxer Posted December 3, 2015 Report Share Posted December 3, 2015 On 12/3/2015 at 8:56 PM, iridebikes said: Some of the bikes haven't got one on from the factory, just put one on and should be fine ???? That can't be right, can it? Quote Link to comment Share on other sites More sharing options...
iridebikes Posted December 3, 2015 Report Share Posted December 3, 2015 On 12/3/2015 at 10:46 PM, johnnyboxer said: ???? That can't be right, can it? I'm pretty sure I've read it somewhere, I might not be right though... Quote Link to comment Share on other sites More sharing options...
dan williams Posted December 4, 2015 Report Share Posted December 4, 2015 (edited) That would have to be a Monday bike. After an open bar party. Assembled by the "new" guy". There's no way for us to assess any damage but if you haven't seized it and it still seems to have plenty of power you might have got away with it. There are several threads where a 4T owner reports a missing impeller. Sounds very weird. Some believe it broke apart and may be wedged in pieces somewhere in the cooling system. Might be worth dropping the hoses and back flushing the radiator and cylinder. I replaced the impeller on my 2T with the aluminum Jitsie but the website says it won't fit the 4T. Edited December 4, 2015 by dan williams Quote Link to comment Share on other sites More sharing options...
johnnyboxer Posted December 4, 2015 Report Share Posted December 4, 2015 On 12/4/2015 at 1:50 AM, dan williams said: That would have to be a Monday bike. After an open bar party. Assembled by the "new" guy". There's no way for us to assess any damage but if you haven't seized it and it still seems to have plenty of power you might have got away with it. There are several threads where a 4T owner reports a missing impeller. Sounds very weird. Some believe it broke apart and may be wedged in pieces somewhere in the cooling system. Might be worth dropping the hoses and back flushing the radiator and cylinder. I replaced the impeller on my 2T with the aluminum Jitsie but the website says it won't fit the 4T. So - you have a water pump & no impeller How very weird? Quote Link to comment Share on other sites More sharing options...
guys Posted December 4, 2015 Report Share Posted December 4, 2015 If there's a circlip on the impeller axle, I would think there was an impeller mounted.If it was my bike I would, as Dan said, dismantle the cooling system as much as possible flush everything through and conduct a very thorough inspection. Quote Link to comment Share on other sites More sharing options...
goudrons Posted December 4, 2015 Report Share Posted December 4, 2015 If it's the same crappy piece of plastic as they use in the 2T, it's highly likely it's still in the coolant system somewhere. I've never seen a 2T one that didn't look like a starving dogs chew toy, even after only a few hours use. If it is or isn't in there, it's worth following Dan's advice and cleaning out the system, just to be sure. Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted December 4, 2015 Author Report Share Posted December 4, 2015 Thanks for the reply's guys Quote Link to comment Share on other sites More sharing options...
reggie Posted December 5, 2015 Report Share Posted December 5, 2015 It is not the same crappy piece of plastic as the 2 stroke, it is a different part number 1620900 000 1 Quote Link to comment Share on other sites More sharing options...
dan williams Posted December 5, 2015 Report Share Posted December 5, 2015 I just looked at two parts lists and found the impeller on both. What year is your bike? Quote Link to comment Share on other sites More sharing options...
guys Posted December 5, 2015 Report Share Posted December 5, 2015 On 12/4/2015 at 9:54 PM, pudrev3 said: Thanks for the reply's guys Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted December 5, 2015 Author Report Share Posted December 5, 2015 Ok cheers, is there any way of getting a metal Impeller custom made ? because by the sounds of it the plastic ones won't last right long Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted December 5, 2015 Report Share Posted December 5, 2015 On 12/5/2015 at 7:33 AM, pudrev3 said: Ok cheers, is there any way of getting a metal Impeller custom made ? because by the sounds of it the plastic ones won't last right long Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted December 5, 2015 Author Report Share Posted December 5, 2015 It's a 2014 model Quote Link to comment Share on other sites More sharing options...
