daveyboy467 Posted December 5, 2015 Report Share Posted December 5, 2015 Hi guys, New to trials. I have txt 280 pro. I started bike, then rode it on gentle throttle / low speed 1st & 2nd gear. Within 5 mins the cooling fan came on and stayed on continuosly until stopping the bike. Is this normal? If not how do i check coolant level & how do i check the water pump ? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 5, 2015 Report Share Posted December 5, 2015 Better that the fan runs than not. Pull the tank to get to the radiator cap. Quote Link to comment Share on other sites More sharing options...
daveyboy467 Posted December 6, 2015 Author Report Share Posted December 6, 2015 Had a quick look into radiator.. Its only got water in by looks of it and its a bit scummy.. I took cap off & started the engine, the water is pumping. I will remove and flush the system and clean the radiator. The fuel was what came in the bike, so i will put ne fuel in. I was going to run 60:1 fuel mix maybe 80:1 Quote Link to comment Share on other sites More sharing options...
daveyboy467 Posted December 6, 2015 Author Report Share Posted December 6, 2015 Ps thanks for 'you tube' info Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 6, 2015 Report Share Posted December 6, 2015 (edited) Just take on of the hoses of (when cold) and let it drip. Put it back on and fill with coolant. Dont mess with the torx gold colloured thing in the pump. The pumps do go bad, but they will leak internally, so your oil will come out milkey (if you have a side glass you can spot it). Edited December 6, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
daveyboy467 Posted December 6, 2015 Author Report Share Posted December 6, 2015 Ok thanks will do this tonight Thanks Quote Link to comment Share on other sites More sharing options...
daveyboy467 Posted December 6, 2015 Author Report Share Posted December 6, 2015 (edited) Ive just flushed it, new coolant, new oil, good quality fuel & oil. Its running much better... Fan on & fan off after a couple mins.. Not boiling water. Ive just mixed. 200ml top quality 2t oil with 12ltr of bp ultimate unleaded..... I cant do math... So dunno what ratio that is prob 50/60:1 I will google what 80:1 works out per 1ltr so i know for future. And yes it does look like i need to descale rad...but i'll do that next on list. Edited December 6, 2015 by daveyboy467 Quote Link to comment Share on other sites More sharing options...
jfc Posted December 6, 2015 Report Share Posted December 6, 2015 (edited) 12 L with 200 ml oil is 60:1 hope that helps 80:1 would be 150ml in 12L. Stand by for correction any time soon lol. Edited December 6, 2015 by jfc Quote Link to comment Share on other sites More sharing options...
daveyboy467 Posted December 6, 2015 Author Report Share Posted December 6, 2015 Thanks... Ive not run a 2t since 2007.... 4t easier to run but harder to fix. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 7, 2015 Report Share Posted December 7, 2015 (edited) Just devide 12 by 0.2 and the answer is 60. So its 1 liter of oil on 60 liters of gas. So the amount of gas, devide by the amount of oil (both in liters or mm or whatever). Edited December 7, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
