pschrauber Posted December 6, 2015 Report Share Posted December 6, 2015 (edited) Hi, I' am looking for someone that can manufacture custom made sprockets to my Panda. The bike has a Franco Morini engine, the shaft looks very similar to the one from Fantic's 125 and 200 Minarelli engine but is different in geometry. Any resources as I need just 3 sprockets with 11 teeth for a 428 chain? I have just now a used 11 teeth and a used 13 teeth which comes from a Swedish 125 Monark which had used that engine too. Left to right: - section through the front sprocket, - front sprocket 12 teeth with right shaft diameter but for 50cc Malaguti/Aspes for a Moped chain, - front sprocket 13 teeth for F. Morini with inner dimension, - front sprocket 11 teeth for Minarelli / Fantic, (doesn't fit) Edited December 6, 2015 by pschrauber Quote Link to comment Share on other sites More sharing options...
evoalien Posted December 6, 2015 Report Share Posted December 6, 2015 Rebelgears.com. They can make anything motorcycle needs Quote Link to comment Share on other sites More sharing options...
ducman Posted December 6, 2015 Report Share Posted December 6, 2015 Patrik, have you tryed sachs sprockets?I think they can fit straight on. Quote Link to comment Share on other sites More sharing options...
pschrauber Posted December 6, 2015 Author Report Share Posted December 6, 2015 Patrik, have you tryed sachs sprockets?I think they can fit straight on. Sachs fit's without any clearance, would need just a little widening with a file but the sprockets are for a smaller chain. The previous owner did check that out already and I have this sprocket too as another template for well fitting but sadly not working (from which I have already several) . Quote Link to comment Share on other sites More sharing options...
pschrauber Posted December 6, 2015 Author Report Share Posted December 6, 2015 Rebelgears.com. They can make anything motorcycle needs OK I will try them out I had in-between already ask these guys in the US: http://sprocketspecialists.com/ they haven't answered yet ... if they can't do it I will give Rebelgears a try. To avoid the extra tax costs which have also to be paid for the postage I really would like to order them Europe ... Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted December 6, 2015 Report Share Posted December 6, 2015 Have you tried Talon Engineering? they made me some great one off sprockets. http://www.talon-eng.co.uk/contact-us/ 1 Quote Link to comment Share on other sites More sharing options...
pschrauber Posted December 6, 2015 Author Report Share Posted December 6, 2015 Have you tried Talon Engineering? they made me some great one off sprockets. http://www.talon-eng.co.uk/contact-us/ No haven't tried them out as I did not knew that they also do custom work. ... Well ... if the first contacted will refuse I give them - to save some €€€ - of course a try. Quote Link to comment Share on other sites More sharing options...
stan wellback Posted December 7, 2015 Report Share Posted December 7, 2015 try www.sprocketsunlimited.com you could buy what they call a blank, this is a sprocket of the size you need but it only has a small hole in the middle. you can get have it machined to fit your original at your local machine shop. they have a big selection and wide knowledge! Quote Link to comment Share on other sites More sharing options...
collyolly Posted December 19, 2015 Report Share Posted December 19, 2015 Talon should be able to help, I supplied them with a special toothed wheel for my Ariel and they 'broached' in the internal spline for me so they do do specials. Quote Link to comment Share on other sites More sharing options...
guys Posted December 19, 2015 Report Share Posted December 19, 2015 This firm in Belgium can make anything you want.I gave a drawing from the rear sprocket from my Montesa 315R to an MX dealer and he passed it on to Kit Cross, and they made one for me for the normal price of a rear sprocket. http://www.kitcross.com/fr/kit-cross.php Quote Link to comment Share on other sites More sharing options...
