Custom Made Sprockets
pschrauber
Hi,
I' am looking for someone that can manufacture custom made sprockets to my Panda. The bike has a Franco Morini engine, the shaft looks very similar to the one from Fantic's 125 and 200 Minarelli engine but is different in geometry.
Any resources as I need just 3 sprockets with 11 teeth for a 428 chain? I have just now a used 11 teeth and a used 13 teeth which comes from a Swedish 125 Monark
which had used that engine too.
Left to right:
- section through the front sprocket,
- front sprocket 12 teeth with right shaft diameter but for 50cc Malaguti/Aspes for a Moped chain,
- front sprocket 13 teeth for F. Morini with inner dimension,
- front sprocket 11 teeth for Minarelli / Fantic, (doesn't fit)
Edited by pschrauber
Patrik,
have you tryed sachs sprockets?I think they can fit straight on.
Sachs fit's without any clearance, would need just a little widening with a file but the sprockets are for a smaller chain.
The previous owner did check that out already and I have this sprocket too as another template for well fitting but sadly not working
(from which I have already several) :hyper: .
Rebelgears.com. They can make anything motorcycle needs
OK I will try them out I had in-between already ask these guys in the US:
http://sprocketspecialists.com/
they haven't answered yet ... if they can't do it I will give Rebelgears a try.
To avoid the extra tax costs which have also to be paid for the postage I really would like to order them Europe ...
