Sherco 125 2006 Graphics
malcolm
Be cautious with most of the factory replacement decals as I've purchased many for several of my different Sherco's and the problem is that the adhesives do not stick worth crap and are pretty much useless unless you try glue on with some other form of glue. The problem is that the adhesive on them has spoiled with age:-( and no it is not just that the fender has not been degreased properly with proper solvent etc.... I believe there is a ''new style'' set to fit the '06-09's with better adhesion properties, try splatshop or local dealer to see if they can get them. Good luck
