Short Stroke Ariel 500
robcbsa
Hi Guys i'm after some info on Ariel short stroke motors I've got the start of a project ie a bottom end crank cases steel flywheels later rod also a 350 head which I've been told can be modified to fit a 500 short stroke barrel there are a number of people selling these are any more preferable for this mod as I think i'll have move the head bolt hole centers ?
I have seen a 350 head modified to fit, but as I understand it, it is A LOT of work. I know the remade 500 heads are expensive but it's worthwhile. As far as I know only Mick Dickenson does the barrels for short stroke. Maybe a few places sell them but they come from the same person I think.
  • Like 2
Hi,
I had similar plans, when I owned my Ariel, a number of people gave me considerable help.  John Bartram from South Street, South Molton, Devon and a chap on here Jonv8 (Jon Cull) Bath area , Nick Smith also from Devon, George Greenland is also well worth talking to as he also had some considered and valuable input and in my opinion built one of the nicest short stroke Ariels I have seen.  John Budgen does barrels and heads.  Mick Ash makes gears for the Burman box.
I would have liked to have completed the project but did not want to spend a disproportionate sum of money on an a bike already well above my capability.  so I left mine long stroke.
I've just picked up a 1985 59n model ty. It has a chrome frame and Swingarm, I've never seen one like it before and wondered if it was some sort of special or just done by someone who wanted something a bit different? The chap I bought it off thought it had been like it from new. I've bought it as a winter project and wanted to get it all powder coated and looking nice. Has anyone seen one like this?
Cheers
I owned a very nice TY in the southern centre, sold it and the next time i saw that it was chromed
Have you got 500 crankcases ? I think they have 5 stud mounting for the barrel and the 350 has 4 stud although it is probably just a simple matter of drilling and tapping the missing fastener as the castings were possibly all the same.
The head I think you want has an internal exhaust port rather than an external stub, these are now becoming rare and expensive.
I have a short stroke bike and it 'rides light' compared to the long stroke original in fact feels very modern, well worth the effort if you can source all the parts.
The idea of the short stroke is mainly that it picks up quicker,and equally important - shuts down quicker.The original longstroke motor is a lovely engine to use,but is a real handful in todays tighter sections.Its also an inch shorter in height and a bit lighter,all of which helps.
The parts needed are a 350 crank and rod assembly,a short stroke barrel from Mick Dickenson. You then need an 86mm piston,usually an XT350 or XT500 Yamaha one.The standard 500 head is used,often with the inlet stub cut off and rewelded to get it inline with the bike,rather than sticking out the side. A Mk1 Concentric or Villiers S22 carb does the fuelling. For ignition some people hide a modified Electrex world unit on the end of the crank,the one made for C15's can be made to fit.Others use the Interspan electronic mag or the BTH electronic unit.Few seem to use an original Wader or BTH mag,or if they are there it is for show only...
The only problem I can see,besides the overall expense is to make sure you don't create an engine that it too much to handle,compression plates and a healthy amount of ignition retard are the order of the day.
Hi Guy's.
Hi TRF.
OK quick run through.
First you need a NH 350 bottom end. with everything in New or good order.
You need to drill and tap a fifth stud hole for the Mick Dickinson short alloy barrel.
You now need to try and find a HT VH cylinder head ,near impossible now, so you will have to buy a newly cast one.
You then need to find a Yamaha XT 350 piston or one with the same measurements.
A month of meticulous machining and assembly and you may have a Scottish winning motor.
PS and a BT-H electronic magneto. and Villiers S22 carb.
Regards Charlie. Sorry Jon you got there before me.  edit because I was to late , always am.
Edited by charlie prescott
Hi Guys thanks for the info had a great chat with Alan Whitton & then Mick Ash both very helpful , My stumbling point is the head I just lost one to a fellow club member . I asked Mick about using a modified 350 head but from the problems he had it looks like a no go, My next plan is to talk to Alan again & see what size the bore of a Mick Dickenson barrel is pre machining & if will take a smaller liner with enough room a less modified 350 bolt patten without welding If it could take a 78mm id liner gives a 400cc engine with small ports & valves to keep gas speed up at low RPM a Honda CRF250 piston has been used by somebody to give me the best of both worlds .
Your thoughts as always are most welcome gentlemen.
Rgs Rob
Depends on what sort of end product you are after, if it's the kudos of a 500 then build a 500 if not why not just build a good 350 out of relatively standard parts ?
You will still end up with a pre-unit bike that is lighter than the A.M.C. and Enfield competition and unless you are doing the harder routes at the national trials (Miller or Kia) do you really need the power ?
