hhadrian1 Posted December 13, 2015 Report Share Posted December 13, 2015 1st gear on the 4ride,standard 10/41 gearing,is the same as 2nd gear on the 4rt on 10/41 gearing. My question is if you ride a Montesa 4rt on 10/41 gearing what would you use 2nd gear for. Quote Link to comment Share on other sites More sharing options...
cornishtwinspring Posted December 13, 2015 Report Share Posted December 13, 2015 Going back to the van after the trial 2 Quote Link to comment Share on other sites More sharing options...
hhadrian1 Posted December 13, 2015 Author Report Share Posted December 13, 2015 (edited) Going back to the van after the trial So you never use 2nd in a section ever,why even have it there surely it's just extra weight ? Edited December 13, 2015 by hhadrian1 Quote Link to comment Share on other sites More sharing options...
cornishtwinspring Posted December 13, 2015 Report Share Posted December 13, 2015 Was intended as humourous, but no its very rare 2nd gets used & 3rd once in the 8mnths iv had her! Quote Link to comment Share on other sites More sharing options...
hhadrian1 Posted December 13, 2015 Author Report Share Posted December 13, 2015 Was intended as humourous, but no its very rare 2nd gets used and 3rd once in the 8mnths iv had her! Would I be right in saying that more expert riders like the gearing higher,and less experienced riders like to feel the bike is not running away with them. Quote Link to comment Share on other sites More sharing options...
the addict Posted December 13, 2015 Report Share Posted December 13, 2015 Going back to the van after the trial Quote Link to comment Share on other sites More sharing options...
the addict Posted December 13, 2015 Report Share Posted December 13, 2015 (edited) This time of year 3rd and 4th gets plenty of action on Gerty, in the dry though its always 1st gear no matter what gets put infront of her. Edited December 13, 2015 by the addict Quote Link to comment Share on other sites More sharing options...
cornishtwinspring Posted December 13, 2015 Report Share Posted December 13, 2015 Didn't know they had 4th!!!.Everyone down here runs either 9/41 or 9/42 whether expert or not. 1 Quote Link to comment Share on other sites More sharing options...
the addict Posted December 13, 2015 Report Share Posted December 13, 2015 Didn't know they had 4th!!!.Everyone down here runs either 9/41 or 9/42 whether expert or not. 9/42 is spot on, pulls 4th really well Quote Link to comment Share on other sites More sharing options...
sportsawyer Posted December 13, 2015 Report Share Posted December 13, 2015 (edited) On my 4RT for trials, I usually use 1st, may use 2nd in one or two sections at a trial, and rarely use 3rd in sections... maybe one or two sections a season. That's using a 10-42 final drive -- one tooth up on the wheel sprocket. For trail riding with a 4RT, I almost never use 1st, and I'm usually in 3rd or 4th. Since you're asking about the 4-RIDE, I think the trail riding is more pertinent. And it looks like Montesa is using gearing changes on the 4-RIDE that will be good for trail riding, with very even jumps gear-to-gear. With a 4RT on trails, I often want a gear higher than 3rd, but 4th is a little too big a jump. And when I want something higher than 4th, 5th is way too big a jump (on trails, if I need it for the road the jump is OK). Edited December 13, 2015 by sportsawyer Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted December 13, 2015 Report Share Posted December 13, 2015 (edited) I use second quite a bit in sections, just depends on the section. I have even gone into many running second the hole ride just to save from needing to shift where it would have ben an inconvenience to go up to second right before a steep hill or larger obstacle. And I ride stock gears on my 4RT for reference. Edited December 13, 2015 by jonnyc21 Quote Link to comment Share on other sites More sharing options...
hhadrian1 Posted December 13, 2015 Author Report Share Posted December 13, 2015 I use second quite a bit in sections, just depends on the section. I have even gone into many running second the hole ride just to save from needing to shift where it would have ben an inconvenience to go up to second right before a steep hill or larger obstacle. And I ride stock gears on my 4RT for reference. Thanks. Having watched the southern experts trial at Butser lime works momentum seems to be so important. I cannot quite see how that can be maintained in a very low gear.Interested in understanding how gearing works in a trials bike and how that relates to the 4ride which is a 4rt with more evenly spaced higher gear ratios. 2 Quote Link to comment Share on other sites More sharing options...
the addict Posted December 13, 2015 Report Share Posted December 13, 2015 Thanks. Having watched the southern experts trial at Butser lime works momentum seems to be so important. I cannot quite see how that can be maintained in a very low gear.Interested in understanding how gearing works in a trials bike and how that relates to the 4ride which is a 4rt with more evenly spaced higher gear ratios. Muddy trials need high gears and momentum as you said, grippy or tight sections need lower gears quite often, you'd get nowhere in the **** in first gear on any bike let alone a 4rt 1 Quote Link to comment Share on other sites More sharing options...
johnnyboxer Posted December 13, 2015 Report Share Posted December 13, 2015 Thanks. Having watched the southern experts trial at Butser lime works momentum seems to be so important. I cannot quite see how that can be maintained in a very low gear.Interested in understanding how gearing works in a trials bike and how that relates to the 4ride which is a 4rt with more evenly spaced higher gear ratios. Exactly I use 1st in tight stuff (9/42), but where a climb is coming up, I sometimes use 2nd for the whole section or snick up into 3rd for a steep climb (and then just hang on ) Between sections on open ground or moors, I quite often enjoy a blast in 5th The gearbox has gears, to be used 1 Quote Link to comment Share on other sites More sharing options...
trialsash965 Posted December 16, 2015 Report Share Posted December 16, 2015 Just bought a new Mont, after my first ride thinking of lowering the gearing slightly from the standard 10/41 but I'm thinking 9 on the front might make it a bit to low geared? Also a trials dealer told me if I run a 9 on the front it will wear the plastic swinging arm guard away? Thanks Quote Link to comment Share on other sites More sharing options...
