Gear Change Shaft
huski
Just changed it ,very easy Clutch cover off,remove complete clutch by undoing centre Allen bolt,two 5 mm bolts hold selector assy in place,remove these and shaft knocks out through clutch side,takes quite a whack.If it goes again I'll upgrade it to the 2015 shaft,but the 2014 one is only £40 delivered from Haven Trialsport,received it next day
  • Like 2
