irishjohn Posted December 17, 2015 Report Share Posted December 17, 2015 I need to replace my fork seals on my 1995 Jt25. I understand that in that year, GG used two different forks which of course require two different seals. Is there a way to determine which size seals I need without disassembling the forks? My concern is, GG parts are a little hard to come by in my neck of the woods. I am reluctant to pull the seals to measure them and then discover the ones I need are not available. Quote Link to comment Share on other sites More sharing options...
bilks Posted December 17, 2015 Report Share Posted December 17, 2015 Check here https://www.youtube.com/watch?v=_PMt6GoKk0Y Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 17, 2015 Report Share Posted December 17, 2015 Well the inside is quite easy just measure the fork. The outside should also be able to find out if you know the possibilities. Take the dust cover off, and make a guess. Quote Link to comment Share on other sites More sharing options...
cbutler Posted December 17, 2015 Report Share Posted December 17, 2015 I need to replace my fork seals on my 1995 Jt25. I understand that in that year, GG used two different forks which of course require two different seals. Is there a way to determine which size seals I need without disassembling the forks? My concern is, GG parts are a little hard to come by in my neck of the woods. I am reluctant to pull the seals to measure them and then discover the ones I need are not available. Call Mike at the Tryals Shop he can and will help you out. http://www.tryalsshop.com/index.html Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 18, 2015 Report Share Posted December 18, 2015 (edited) I believe you need to take them apart. They come apart very easily if I`m thinking of the right bike. The whole fork seal cup comes apart.(It just unscrews by hand) The problem is the first batch of bikes (I`m guessing here) took 38X48 seals. And then they came out with 38 X 50 seals and the whole cup was changed. Some bikes got the new parts warranted and some did not. I think the original was red wipers and the new one`s were green. I`m sure it was the `95`s as I remember at the first national it was quite entertaining. GasGas had a line of bikes replacing the fork seal cups, and the Fantic Importer had a line of bikes replacing the intake manifolds on the early Sections! The early 95 250`s were quite a problem, now that I think about them. That was the year Gas Gas tried to water cool the center cases! All kinds of corrosion and expense! Edited December 18, 2015 by lineaway 1 Quote Link to comment Share on other sites More sharing options...
irishjohn Posted December 18, 2015 Author Report Share Posted December 18, 2015 Lineaway, I was afraid of that... Mine has the red wipers. I just didn't want to pull them apart then find the seals were not available. I guess after Sunday's meet, I'll tear them down. Not heard about the water cooled cases. Was that a feature on the '95 250's? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 19, 2015 Report Share Posted December 19, 2015 Yes, the `95 started with water cooled cases and then Gas Gas came out with a Base Gasket Kit to block the water to the cases. Trouble is communication was not very good back then (Is it now?) and not all owners got the parts necessary to fix the corrosion issue. Telling someone their new bike was going to rot away quickly probably was not a priority. Quote Link to comment Share on other sites More sharing options...
irishjohn Posted December 21, 2015 Author Report Share Posted December 21, 2015 Thanks for the info. It's always something... Quote Link to comment Share on other sites More sharing options...
