Fantic 200 (Rear Kick) Exhaust
samwisemcg
I should have added that the front pipe can also get blocked. I poured petrol into mine and threw it on a bonfire. That seemed to work ok but I did the same for the silencer and ended up having to cut both ends of the silencer open.Inside I found the holes in the baffle plates completely blocked by carbon.
Good luck
Used a regular gas blow torch and a compressor blow off gun to clean mine. Great fun !!!!! Took a few minutes to get it going but well worth it.
Basically you fire the air and the butane torch up one end of the pipe until it starts to roar. You will know when its started to work. You can then remove the gas torch but keep the compressed air on.
Almost worth buy old two stroke pipes so you can do it for fun.
