207/307 ?
thescoot
Hi guys and merry Christmas to you all. I have recently purchased an air cooled mono with a view to reliving my youth. Its a Fantic but its had a hard life and is in need of restoration. Problem is, I don't know which model it is. Its pretty obvious that its either a 247 or a 307. You know, upside  down forks, fluro orange paint etc. Frame numbers are FM36406082 but there are no numbers or engine size markings whatsoever. Does anyone have any hints or tips on where I could check which model it is. I will be pulling the top of to check all is well but would like to source some parts first. Any info greatly appreciated.
Engine # is stamped on a machined flat surface kinda under the carb towards the right side , you should be able to clean it and read it with a little patience ,and maybe a mirror . :)
Glenn
And Bill Pye is your parts source for anything Fantic in the UK
Edited by axulsuv
