315R/2005 4Rt Swingarm
r6eck
Will only work on later 315's with inboard rear disc. If earlier 315 you will need to use wheel and brake assy from 4RT as well.
Unless you mean you want to use a 315 arm to go in a 4RT in which case you will need an arm from a late 315 (inboard disc caliper type)
Hope that makes sense...
Edited by lsv
