mcman56 Posted December 30, 2015 Report Share Posted December 30, 2015 My throttle can open on its own in certain situations and this can be a bit alarming. The cable must get caught on the little velcro tab on the bar pad. Are my cables routed correctly? It looks like the throttle cable could go over the clutch line but then the clutch line may pull the cable also. I could try running the pad cover inside out or maybe attaching the the pad on from the bottom with tie wraps. Or...is this why Betas come with the special pad...which I don't have. Quote Link to comment Share on other sites More sharing options...
dan williams Posted December 30, 2015 Report Share Posted December 30, 2015 Mine didn't come with a bar pad. Just a rubber dingus that fits over the bar clamps. Quote Link to comment Share on other sites More sharing options...
jfc Posted December 30, 2015 Report Share Posted December 30, 2015 I think you need the correct bar pad! That looks like quite a large / bulky pad. Quote Link to comment Share on other sites More sharing options...
westygas270 Posted December 30, 2015 Report Share Posted December 30, 2015 ive tried one of these on my bike m8 renthal pad. i would suggest take it off pal i tried different things and it is the velcro that catches the throttle cable when your going left to right, you can actualy get a beta pad, its not anywhere as big as that and is rubber that goes over the handlebar clamps, they fit both the hinge type and standard clamps and defo dont catch the cables Quote Link to comment Share on other sites More sharing options...
westygas270 Posted December 30, 2015 Report Share Posted December 30, 2015 This is what you want Quote Link to comment Share on other sites More sharing options...
steve_earle Posted December 30, 2015 Report Share Posted December 30, 2015 Get the jitsie bar pad, I have one on mine, It's smaller than the renthal and you can angle it down to clear better. Quote Link to comment Share on other sites More sharing options...
markmac25 Posted December 30, 2015 Report Share Posted December 30, 2015 i use an s3 bar pad, its alot smaller that the renthal, around 15 pound on trialendurodirect, (if you want a standard one im sure if you contact beta uk direct they will have them) they are very very helpful Quote Link to comment Share on other sites More sharing options...
