okjc250 Posted January 2, 2016 Report Share Posted January 2, 2016 Seems to be a pattern occurring with my mates txt..... problematic Firstly will only start on the choke....... any ideas? secondly any wet action and it gets in the airbox and doesn't drain out of the little reed valve.... some tape over airbox cover should sort this Lastly and most worrying engine is starting to sound a bit rattly... top end .... bottom end have no idea to be honest Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted January 2, 2016 Report Share Posted January 2, 2016 (edited) From you title it sounds like you are breeding them All TXT's rattle, its normally the clutch Watch you don’t block the air from entering the airbox, you will have even more problems. Better to fix the valve at the bottom? If it’s hot and you need the choke, have a look on youtube for videos setting the carb Edited January 2, 2016 by suzuki250 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 3, 2016 Report Share Posted January 3, 2016 You should clean the airfilter box and make sure the little flap underneath functions, this should make it able for water to drain. Quote Link to comment Share on other sites More sharing options...
okjc250 Posted January 3, 2016 Author Report Share Posted January 3, 2016 I cleaned the valve out last time. But this time when it started bogging down a little I pulled the whole valve out and loads of water came out. As if the weight of the water isn't enough to open it. I left it out for the rest if the day Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 3, 2016 Report Share Posted January 3, 2016 Maybe the plastic became to hard, you can try a new one? http://www.2bbikes.com/Webwinkel-Product-134033183/ontwatering-filterbox-flap.html Quote Link to comment Share on other sites More sharing options...
okjc250 Posted January 3, 2016 Author Report Share Posted January 3, 2016 Could be worth a try thanks Quote Link to comment Share on other sites More sharing options...
okjc250 Posted January 3, 2016 Author Report Share Posted January 3, 2016 The photos I have seen from that part number doesn't look like what I am talking about. It's like a little rubber grommet in the bottom of the airbox Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 3, 2016 Report Share Posted January 3, 2016 (edited) Could be that the 2003 model (or 2002?) has a different design. 2004+ has this design (probably with a reason) Edited January 3, 2016 by crazybond700 Quote Link to comment Share on other sites More sharing options...
okjc250 Posted January 3, 2016 Author Report Share Posted January 3, 2016 Pretty sure it's 2003 could be a year earlier though. Can't find a part number for this little grommet anywhere Quote Link to comment Share on other sites More sharing options...
huski Posted January 3, 2016 Report Share Posted January 3, 2016 My 04 Gasgas had a rubber sheet splash guard cable tied to the frame ,visible when the airbox was removed.A mate had an 03 which didn't have it and a different airbox which would have been a good aquarium,the dirty water ruined the motor.Id recommend getting the later airbox and splash guard.Richard Allens Trialspares would be a good place to start Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 4, 2016 Report Share Posted January 4, 2016 But the airfilter is really different aswel. So if it has the ''bowl'' airfilter its a pro, if it has a side flat airfilter its an edition. (among other differences) Quote Link to comment Share on other sites More sharing options...
okjc250 Posted January 4, 2016 Author Report Share Posted January 4, 2016 It is a 2003 pro. Going to make up a little splash guard and take airbox out see what else I can seal to help Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 4, 2016 Report Share Posted January 4, 2016 I know the 2002 pro airbox was really bad, and they changed it. I think also electronics ran trough it? The 2003 I have not had problems with on numerous bikes, but we might have weather differences, we do not ride creeks or something overhere. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 4, 2016 Report Share Posted January 4, 2016 A new underside of the filter isnt that expensive http://www.2bbikes.com/Files/2/70000/70237/ProductPhotos/Large/243451143.jpg http://www.2bbikes.com/Webwinkel-Product-134036555/filterbox-onderste-gedeelte-pro.html Although not completely sure if its fits your ''painted'' parts. Quote Link to comment Share on other sites More sharing options...
okjc250 Posted January 4, 2016 Author Report Share Posted January 4, 2016 That could be worth a go... will speak to my mate see what he wants to do Quote Link to comment Share on other sites More sharing options...
