woody Posted January 10, 2016 Report Share Posted January 10, 2016 A couple of local lads bought a new 4RT each a few months back and are having issues with the fork seals. One bike sprung a leak on one leg and it was replaced under warranty. It has now blown the other seal and the other bike has also now got a leak from one seal Neither bike has had hard use as they are both novice standard and just go out and play on them, not ride trials. They've only been used half a dozen times. Another rider who had a new 4RT has said it's an issue and replacing the seals with new standard Montesa / Honda seals won't cure the problem, you have to use green seals. The dealer is miles away but will only provide standard replacements under warranty, if they want the green seals they have to pay for them and the price that they've been given (not by the dealer) is something like £60 a pair... Has anyone come across this problem with the latest 4RT and if so how was it fixed? Seems strange to me that Honda should have a problem with fork seals, but both bikes have suffered the same issue and it also happened to the bike belonging to the rider who mentioned the green seals as a fix. Anyone know what the green seals are, or any reliable replacements other than the standard seals if they are in fact giving problems? Quote Link to comment Share on other sites More sharing options...
jimmyl Posted January 10, 2016 Report Share Posted January 10, 2016 Hi Woody = are they std Monts or the repsol. (tech and showa forks) I fancy I had some seepage on my std 15 initially but seem ok now. Quote Link to comment Share on other sites More sharing options...
guys Posted January 10, 2016 Report Share Posted January 10, 2016 (edited) I think they mean the green SKF fork seals, should be very good quality with low friction. The seals below are for the the Showa forks: http://www.splatshop.co.uk/skf-fork-oil-dust-seal-kit-showa-39mm.html These are forthe Tech forks: http://www.splatshop.co.uk/skf-fork-oil-dust-seal-kit-tech-39mm-forks.html Edited January 10, 2016 by guys Quote Link to comment Share on other sites More sharing options...
woody Posted January 10, 2016 Author Report Share Posted January 10, 2016 On 1/10/2016 at 7:49 PM, jimmyl said: Hi Woody = are they std Monts or the repsol. (tech and showa forks) I fancy I had some seepage on my std 15 initially but seem ok now. Good question - I don't know... Well out of touch with modern bikes and forgot there were differences in the suspension, I'll have to find out Quote Link to comment Share on other sites More sharing options...
woody Posted January 10, 2016 Author Report Share Posted January 10, 2016 On 1/10/2016 at 8:00 PM, guys said: I think they mean the green SKF fork seals, should be very good quality with low friction. The seals below are for the the Showa forks: http://www.splatshop.co.uk/skf-fork-oil-dust-seal-kit-showa-39mm.html These are forthe Tech forks: http://www.splatshop.co.uk/skf-fork-oil-dust-seal-kit-tech-39mm-forks.html Thanks Guys 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 10, 2016 Report Share Posted January 10, 2016 Gas Gas BT201303013 Quote Link to comment Share on other sites More sharing options...
woody Posted January 10, 2016 Author Report Share Posted January 10, 2016 Thanks for the replies, I'll pass the info on Quote Link to comment Share on other sites More sharing options...
aussiechris Posted January 11, 2016 Report Share Posted January 11, 2016 I had one fork seal start leaking quite early on (this is Repsol with Showa forks). I too was surprised that this would happen. Upon dismantling the fork, I discovered that the top bushing was faulty. The grey teflon coating was flaking off and bits of it getting into the seal area. I replaced the bush and the seal with genuine parts (both low priced). I like the genuine seal as it is a full double lip (two garter springs) seal. Those green SKF seals look good but are too expensive (at least 4 times the price of a genuine seal). You can get the genuine one from any Honda shop because it fits one of the old XR models. Just quote the part number 51425-NN3-821. It was about AUD$17 from either Honda or the Montesa dealer. The bush was about AUD$12 from the Montesa dealer. Again, this refers to the 39mm Showa forks only. 2 Quote Link to comment Share on other sites More sharing options...
johnnyboxer Posted January 11, 2016 Report Share Posted January 11, 2016 On 1/10/2016 at 7:45 PM, woody said: A couple of local lads bought a new 4RT each a few months back and are having issues with the fork seals. One bike sprung a leak on one leg and it was replaced under warranty. It has now blown the other seal and the other bike has also now got a leak from one seal Neither bike has had hard use as they are both novice standard and just go out and play on them, not ride trials. They've only been used half a dozen times. Another rider who had a new 4RT has said it's an issue and replacing the seals with new standard Montesa / Honda seals won't cure the problem, you have to use green seals. The dealer is miles away but will only provide standard replacements under warranty, if they want the green seals they have to pay for them and the price that they've been given (not by the dealer) is something like £60 a pair... Has anyone come across this problem with the latest 4RT and if so how was it fixed? Seems strange to me that Honda should have a problem with fork seals, but both bikes have suffered the same issue and it also happened to the bike belonging to the rider who mentioned the green seals as a fix. Anyone know what the green seals are, or any reliable replacements other than the standard seals if they are in fact giving problems? I heard the first 2014 260 plain 4RT's had issues with fork seals after only a few hours use Not heard much lately Quote Link to comment Share on other sites More sharing options...
oz thumper Posted January 27, 2016 Report Share Posted January 27, 2016 (edited) On 1/10/2016 at 7:45 PM, woody said: A couple of local lads bought a new 4RT each a few months back and are having issues with the fork seals. One bike sprung a leak on one leg and it was replaced under warranty. It has now blown the other seal and the other bike has also now got a leak from one seal Neither bike has had hard use as they are both novice standard and just go out and play on them, not ride trials. They've only been used half a dozen times. Another rider who had a new 4RT has said it's an issue and replacing the seals with new standard Montesa / Honda seals won't cure the problem, you have to use green seals. The dealer is miles away but will only provide standard replacements under warranty, if they want the green seals they have to pay for them and the price that they've been given (not by the dealer) is something like £60 a pair... Has anyone come across this problem with the latest 4RT and if so how was it fixed? Seems strange to me that Honda should have a problem with fork seals, but both bikes have suffered the same issue and it also happened to the bike belonging to the rider who mentioned the green seals as a fix. Anyone know what the green seals are, or any reliable replacements other than the standard seals if they are in fact giving problems? On 1/11/2016 at 12:55 AM, aussiechris said: I had one fork seal start leaking quite early on (this is Repsol with Showa forks). I too was surprised that this would happen. Upon dismantling the fork, I discovered that the top bushing was faulty. The grey teflon coating was flaking off and bits of it getting into the seal area. I replaced the bush and the seal with genuine parts (both low priced). I like the genuine seal as it is a full double lip (two garter springs) seal. Those green SKF seals look good but are too expensive (at least 4 times the price of a genuine seal). You can get the genuine one from any Honda shop because it fits one of the old XR models. Just quote the part number 51425-NN3-821. It was about AUD$17 from either Honda or the Montesa dealer. The bush was about AUD$12 from the Montesa dealer. Again, this refers to the 39mm Showa forks only. Hi Woody and Chrisa, I have a 2014 Repsol (arrived here at end of year) and have had same experience of seal leak and when stripped issue was Teflon coating pealing off the top bushes, which can get under seal lip as well as in valving. No defects on the surface of the staunchions, and bottom bushes and coating were perfect, so appears to be an issue with the coating adhesion being defective. However point is, after dismantling the forks and meticulous cleaning of all components and replacement of all seals and bushes, after two practice sessions leaking from right fork leg seal. When leg stripped have found the same issue with the new top bushes. The problem does not seem to be seals, (as Chrisa mentions) but the coating on the bushes. My issue is whether or not this is recognised as a problem and where to get satisfactory bushes from? My 2006 Repsol forks have only been rebuilt once and the bushes only showed normal wear not bubbling and stripping of the coating. Anybody have further info? Edited January 27, 2016 by oz thumper Quote Link to comment Share on other sites More sharing options...
helicoptermanr22 Posted January 28, 2016 Report Share Posted January 28, 2016 (edited) I have both forks leak almost at the same time after 4 hours use. Blazeys were superb and replaced the fork sliders (black bit) and seals and all was good again. they said there was a few issues on the tech forks.. Now have a 16 bike so lets see what happens. done 10 hours and all good so far! Edited January 28, 2016 by helicoptermanr22 Quote Link to comment Share on other sites More sharing options...
andat Posted March 23, 2016 Report Share Posted March 23, 2016 Just putting SKF seals in tonight and noticed the Teflon coating on both guide bushes is peeling off. Must be a fault on the 2015 model? Quote Link to comment Share on other sites More sharing options...
oz thumper Posted March 23, 2016 Report Share Posted March 23, 2016 On 3/23/2016 at 10:20 PM, andat said: Just putting SKF seals in tonight and noticed the Teflon coating on both guide bushes is peeling off. Must be a fault on the 2015 model? Andat are these Showa forks? I am still having problems with Teflon stripping off the upper fork guide bushes. Factory say there is no problem with Showa forks Quote Link to comment Share on other sites More sharing options...
trial bike Posted March 24, 2016 Report Share Posted March 24, 2016 One of My 2015 standard 4RT legs leaked copiously a few hours in. My dealer was golden, he had both legs back and they were repaired under a factory warranty. A known issue with some legs apparently. They have since taken some abuse with no issues at all. I'd approach your dealer. Quote Link to comment Share on other sites More sharing options...
aussiechris Posted March 24, 2016 Report Share Posted March 24, 2016 Unfortunately, the dealer(s) here in Australia claim not to have heard of any problem. They've obviously not heard of the internet either. To each individual they will tell you that you are the only one to have had this problem (implying that it is your fault somehow). Clearly, there is a real problem with the Showa fork bushes from 2015 onwards. I say onwards because, as Oz Thumper says, the replacement bushes are failing as well. Very disappointing. Quote Link to comment Share on other sites More sharing options...
