b40rt Posted January 11, 2016 Report Share Posted January 11, 2016 Any suggestions of best sprocket combination ? 10/11 & 42 seems to be the most common. Thanks Ross Quote Link to comment Share on other sites More sharing options...
racehunter Posted January 11, 2016 Report Share Posted January 11, 2016 (edited) Hi Ross, The info I have is that the standard front sprocket was an 11 tooth and that's what I have fitted with a 42 rear. The 10 was an option. Edited January 11, 2016 by racehunter Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 11, 2016 Author Report Share Posted January 11, 2016 Many thanks, it felt a bit high, even with the 10 ! Quote Link to comment Share on other sites More sharing options...
swmtf3 Posted January 11, 2016 Report Share Posted January 11, 2016 I've got a climber bottom end in a SWM with 10-41, and that is fast. Have just ordered a 44 rear. 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 11, 2016 Author Report Share Posted January 11, 2016 I've discovered a 42 in the pile, so will see what that's like. Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 12, 2016 Author Report Share Posted January 12, 2016 10 / 42 is getting there, but 1st feels like a low 2nd. Need to try it properly, would going from 42 to 44 make a noticeable difference ? Quote Link to comment Share on other sites More sharing options...
swmtf3 Posted January 12, 2016 Report Share Posted January 12, 2016 I hope so, three teeth normally makes a big difference on 520 chain. 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 13, 2016 Author Report Share Posted January 13, 2016 On 1/12/2016 at 5:51 PM, swmtf3 said: I hope so, three teeth normally makes a big difference on 520 chain. Thanks, can you post your thoughts when you have tested them. Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 6, 2016 Author Report Share Posted February 6, 2016 Any updates ? Quote Link to comment Share on other sites More sharing options...
swmtf3 Posted February 22, 2016 Report Share Posted February 22, 2016 Hi Ross, 44t was a disaster. Any slight amount of throttle and the front wheel was in the air. I can post it to you if you want to try it? it was good to meet you at Martins stand on Saturday. Cheers, Paul 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 22, 2016 Author Report Share Posted February 22, 2016 On 2/22/2016 at 7:39 AM, swmtf3 said: Hi Ross, 44t was a disaster. Any slight amount of throttle and the front wheel was in the air. I can post it to you if you want to try it? it was good to meet you at Martins stand on Saturday. Cheers, Paul Hi Paul, sorry, a bit dim and didn't work out it was you ! I have had a shot on one in Spain and the gearing was "normal" with a 38 on the back. I will have to try and find out the gearing on the crank / clutch basket is where the difference lies. The water pump was driven from this so this might have necessitated the change ? Cheers Ross 1 Quote Link to comment Share on other sites More sharing options...
papa al Posted April 23, 2016 Report Share Posted April 23, 2016 On 1/12/2016 at 5:19 PM, b40rt said: 10 / 42 is getting there, but 1st feels like a low 2nd. Need to try it properly, would going from 42 to 44 make a noticeable difference ? ~5%. Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 23, 2016 Author Report Share Posted April 23, 2016 On 4/23/2016 at 1:18 PM, papa al said: ~5%. Since discovered climber crankshaft pinion has four more teeth than swm/txr air cooled bottom end. Next job is to swap earlier pinion. The clutch basket will also need swapped as earlier bikes helical cut, climber straight cut. Quote Link to comment Share on other sites More sharing options...
swm Posted April 26, 2016 Report Share Posted April 26, 2016 On 4/23/2016 at 2:59 PM, b40rt said: Since discovered climber crankshaft pinion has four more teeth than swm/txr air cooled bottom end. Next job is to swap earlier pinion. The clutch basket will also need swapped as earlier bikes helical cut, climber straight cut. Hi Ross, please consider why aprilia reduced the ratio transmission on engine pinion/clutch basket....because they reduced the clutch springs load!!!! regards. Quote Link to comment Share on other sites More sharing options...
