Water In Crankcase?
oldgrumps
Had the same thing, oil appeared whitish in the sight glass. Unscrewed the sight glass and everything looked normal inside. Drained the oil, it looked normal as well.  Cleaned the sight glass, and replaced with new oil, problem went away. BTW don't clean sight glass with carb cleaner or the like, despite what the others say. It distorts the plastic slightly and ruins the clarity of the sight glass. Good luck to you
I live in Hawaii, the air temp only gets down to the uppers 50's right now, and that's almost record temps. There is dew outside but my bike is in my enclosed garage. I'm going to rule out condensation. If I keep seeing moisture in the oil I might change the oil seal.
Old
