lockie28 Posted January 15, 2016 Report Share Posted January 15, 2016 I've got a trick for that Quote Link to comment Share on other sites More sharing options...
thesolidman1 Posted January 16, 2016 Report Share Posted January 16, 2016 Had the same thing, oil appeared whitish in the sight glass. Unscrewed the sight glass and everything looked normal inside. Drained the oil, it looked normal as well. Cleaned the sight glass, and replaced with new oil, problem went away. BTW don't clean sight glass with carb cleaner or the like, despite what the others say. It distorts the plastic slightly and ruins the clarity of the sight glass. Good luck to you Quote Link to comment Share on other sites More sharing options...
oldgrumps Posted January 17, 2016 Author Report Share Posted January 17, 2016 What's the trick? Rode today and during the ride saw white fog on the glass. After ride just a tiny white residue remains. Will see how it looks in the morning. Quote Link to comment Share on other sites More sharing options...
steve_earle Posted January 20, 2016 Report Share Posted January 20, 2016 Don't worry about it if the oil is fine after a drain, It's just the cold weather and moisture in the air inside the box separating. I get this in both mine and my son's Evo. Quote Link to comment Share on other sites More sharing options...
oldgrumps Posted January 21, 2016 Author Report Share Posted January 21, 2016 I live in Hawaii, the air temp only gets down to the uppers 50's right now, and that's almost record temps. There is dew outside but my bike is in my enclosed garage. I'm going to rule out condensation. If I keep seeing moisture in the oil I might change the oil seal. Old Quote Link to comment Share on other sites More sharing options...
