New Bultaco: Poor Starter And Stopped Today... Help !
mrooney
Hi
Looking for a little help, pointers and/or where to start. I'm no and#39;mechanic god' so assume nothing.
I bought a 199A sherpa off eBay. Its not been run regularly but it has had quite a bit work done and looks generally tidy. Bit of a risk as bought it unseen. Got delivered home, filled up with fuel/oil mix and  my excitement I managed to start it after several go's. Choke doesn't seem to do much, fiddled on and off. Eventually fired with wide open throttle. Went for a ride and whilst it tick overs quite sweetly seem low on power and does free rev. Can pull a wheelie in any gear for example.
Had another go today. cleaned carb out but nothing in there all clean... looks very new its a Mikuni carb. Went for a ride same symptoms and eventually getting it started again wide open throttle was the only setting to get it going. Again ticked over nicely but not sharp revving. After 5 mins stopped on me. May have left fuel off. Cant get started again ! Gave up !
So in summary:
Low power / revving but good tick over and plenty of torque low down revs.
Terrible to start... killer on the leg and lungs ! Compression good !
I checked for spark, get one not sure if strong but there is one.
Bike obviously not used much been in storage a while I think.
... Where should I start? Need this thing to reasonably reliable. Not called the local motorcycle shop jut yet.
Ideas, pointers very appreciated.
mark
As a first approach, checking of fuel system and ignition is advisable. Have you removed the jets from the carb and ensured they are all clear? Also empty the tank and use fresh petrol, with the correct mix of two stroke oil of course. If you're trying to run it on old stuff then you're on a loser!
Make sure the air filter element is clean, and that the rubber unions attaching to both sides of the carb are properly located and the clips fully tightened.
Would be worth checking the ignition timing, if you're not sure on how to then check back to us here, but as a first line of approach you could clean up the faces of the points through the window in the flywheel using sandpaper over the end of a screwdriver.
Also fit a new plug, easy to do and can work wonders!
Edited by cleanorbust
Could pay to have the carb put through an ultrasonic cleaning bath, if it's not been run regularly then the internal passages can clog. Fairly cheap to do & removes any dried up fuel from the passages & jets
Hi Mark,
Nice bike! I have one just like it.
It looks like a recent restoration, so I'm wondering if the Mikuni is new?  I'd play with the air screw. The carbs come with correct jets but the air will still need setting up properly. Mine certainly did when I swapped it for the original Bing. The symptoms were a lot like you describe.
Wind it all the way in, then back it up two turns. Run the bike and adjust until the tick over levels out. You need a longish screw driver because you need to get in past the exhaust.
Then throw the points away and fit electric ignition!!
Best of luck
Mike
Welcome, and please tell us where you are.
Starting w/Mikuni: choke lever down throttle closed, once started lever back up.
Try to not call the shop as we are here to help you thru this.
Larry
Hi
Just got the last additional posts thanks you.
I think I'll get a new plug tomorrow. I've cleaned it and gapped but looks well worn. Carb I'll look into that. Can't get the bloody thing started at the moment and my leg is dropping off. There is a spark but it looks weak to me.
Points look clean but electronic ignition seems a good thought... How much ?
Still I polished the tank in defeat off starting, bike it looks pretty good even if it doesn't work
New or known good plug first
Clean points and set points gap at 0.35 to 0.4mm
Timing is 3.25 BTDC but there is no reason why it should be wrong.
My guess is its the ignition source coil in the stator of the HT coil.
Fitting electronic ignition?    The standard points set up usually works fine and is a lot cheaper but does need checking every 30 to 50 hours riding.
Edited by dadof2
The head steady is the bracket that connects the Cyl. head with the frame
Also check if the condenser is ok, and mount it under the fuel tank instead of under the ignition cover, it gets to hot there and fails, I'm told.
And make sure the clutch doesn't slip. Even the slightest slipping of the clutch on my 350, makes it very hard to get it going.
Edited by guys
As above you need the headsteady. Also i have same bike with electric ignition easy tofit and just for get about it saves all the messing about with points mine was stood for 8 months fresh fuel started straight away no trouble. some like them some don't mine runs great on 1 would recommend buying 1
As above you need the headsteady. Also i have same bike with electric ignition easy tofit and just for get about it saves all the messing about with points mine was stood for 8 months fresh fuel started straight away no trouble. some like them some don't mine runs great on 1 would recommend buying 1 p.s if you plane on riding a plastic tank would be better be ashame to ruin the Alloy tank if you come off.
