3nex Posted January 17, 2016 Report Share Posted January 17, 2016 Hello everyone, I am not a trial rider at all, I only enjoy watching the sport. I just have a short question I've been wondering about. Is there a video on Youtube for example, that shows how a trial section is being built? Because sometimes watching those constructions, it makes me wonder how the whole thing stays upright so sturdy. Sometimes it's obvious if it's a cement block or something, but for some very tall and relatively thin constructions, it seems like it should be fairly easy to knock down when "slamming into it" with a bike. So I'm wondering if there is a video where someone shows the process of building it, maybe talking about it as well. Thanks in advance 1 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 17, 2016 Report Share Posted January 17, 2016 Not a video, but usually the stuff is pretty heavy. We use a lot of wood here, from old train tracks. That together with poles (as used for fences) makes a good base. Big rocks and stones stay where they are almost by themselfs, a bit of sand and they dont go anywhere. Big concrete pipes are also blocked with sand. Quote Link to comment Share on other sites More sharing options...
3nex Posted January 17, 2016 Author Report Share Posted January 17, 2016 (edited) Right. Well I get rocks, and sand of course. That other stuff, I guess it depends on what you do with it... But what about these two for example: http://imgur.com/a/bC3Og ?These seem kind of "counter-intuitive". The blue pipe would look easy to knock down when you ram it, unless it's filled with cement all the way from top to bottom? The yellow one even worse, either easy to knock down or weak enough to fall through... Edited January 17, 2016 by 3nex Quote Link to comment Share on other sites More sharing options...
ftp Posted January 17, 2016 Report Share Posted January 17, 2016 Its all concrete - and weighs tons....... literally. Quote Link to comment Share on other sites More sharing options...
ourian Posted January 17, 2016 Report Share Posted January 17, 2016 The yellow ones look like they are made from reinforced concrete and probably weigh nearly half a ton each, they are also ratchet strapped together. The blue ones are either steel, timber or concrete maybe a mixture of all three, they'll either be weighed down by filling with concrete or sand, maybe special straps holding them together or bolted to the floor. Quote Link to comment Share on other sites More sharing options...
pro sport Posted January 17, 2016 Report Share Posted January 17, 2016 (edited) All heavyweight stuff moved around and set up with forklifts and telehoists. I did see a bit of video about Mart and Dougie Lampkin planning and setting up an indoor course , try U tube search! Edited January 17, 2016 by pro sport Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted January 18, 2016 Report Share Posted January 18, 2016 And I see a yellow band around the yellow concrete stuff. But they probably weight ALOT. Quote Link to comment Share on other sites More sharing options...
