jonnyc21 Posted February 11, 2016 Report Share Posted February 11, 2016 (edited) I am confused, the only thing I have disconnected at this point is the bank angle sensor. I don't have anything else unplugged. I am also wondering if maybe I had spark the hole time and just couldn't see it, and am also considering plugging the bank angle sensor back in and having the wife check for spark again... (got the wife to check when I was kicking it over.) Edited February 11, 2016 by jonnyc21 Quote Link to comment Share on other sites More sharing options...
ramz Posted February 11, 2016 Report Share Posted February 11, 2016 I clipped this from someone's post: If it takes more than 3 kicks or so to start, reset the ECU. This is from the 2014 or 2015 manual, right after the Contents page:If you have problems starting your vehicle, follow the steps below:1. Open the throttle all the way (100%) and hold.2. Without releasing the throttle, operate the kick-starter once or twice.3. Close the throttle and start your motorcycle as normal. 1 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted February 11, 2016 Report Share Posted February 11, 2016 This is one of the fist things I tried. Quote Link to comment Share on other sites More sharing options...
sportsawyer Posted February 11, 2016 Report Share Posted February 11, 2016 I am confused, the only thing I have disconnected at this point is the bank angle sensor. I don't have anything else unplugged. I am also wondering if maybe I had spark the hole time and just couldn't see it, and am also considering plugging the bank angle sensor back in and having the wife check for spark again... (got the wife to check when I was kicking it over.) Unless you've replaced the stock kill button with a lanyard kill, I'd reinstall the bank sensor. If you want to remove the bank sensor, you'll need to jump the outer contacts of the connector as others had said. You could stick a fat wire in the plug cap, grab ahold, and give the bike a good kick. That should tell you if there's power to the plug. 1 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted February 11, 2016 Report Share Posted February 11, 2016 If you have the standard breather system still connected and bike has been upside down - check air box for oil as this is where it eventually gets dumped. may be saturated air filter or oil in Throttle body.?? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted February 11, 2016 Report Share Posted February 11, 2016 Good thought but the bike wasn't upside down just fell far enough for me not to be able to pick it back up in time for it to stop running. I did check the air box just in case but maybe I should just pull it and the throttle body and give them both a good check and clean. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted February 11, 2016 Report Share Posted February 11, 2016 Jonathon, Check your throttle cable at the lever end. I had an upside down moment that pulled the cable out of the grip about 1/4". Bike simply would not start. Pushed it in - magic! 1 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted February 11, 2016 Report Share Posted February 11, 2016 Should have included that I checked that as well. Have the normal play in the cable and small amount of movement on the throttle tube before engaging. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted February 12, 2016 Report Share Posted February 12, 2016 (edited) I figured out the issue. So it turns out I had 2 issue, and I think I know how I got both... The first issue turned out to be my Bang Angle sensor, and was the cause of not having spark. When plugged in I get nothing, when bypassed I have spark. The second issue turns out to have been caused by me pulling everything apart. Not sure if it was the former owner but it turns out that when I pulled the plug to check the spark the wire to the fuel pump was wrapped around it and was tugged just a fraction out of its connector and as I had not removed the fuel tank I didn't even see it as a possible issue. After figuring out I did in fact have spark with the sensor bypassed I turned to possible fuel pump issues and so pulled the tank to check the pump. So as I pulled the tank the connector almost fell apart just half removing the tank so I re-connected it and the bike started second kick. Thank you to everyone for your help. Great bunch of people here! Edited February 12, 2016 by jonnyc21 4 Quote Link to comment Share on other sites More sharing options...
