Exhaust Bung Issue?
stpauls
I have just replaced the clutch side crank shaft seal on a Sherco 2T.  I have always used an exhaust bung when I wash my bike.  I was wondering if running the engine with an exhaust bung still inserted into the end of the tail pipe would explain the damaged crank shaft seal?
         Exhaust bung
Edited by stpauls
Done it myself a couple of timed by accident. I now use the champagne cork from my previous weekend victory celebrations, this acts as a pressure relief valve, when the exhaust pressure builds the cork pops across the garage forecourt. Apart from a few strangers with a black eyes, no harm done.
It certainly won't help, the pressure has to escape somewhere. Why would you do that ?
I always warm the engine up after washing the mud off.  I have close neighbours and the bung reduces the volume a lot.  I bet this is what caused the crank shaft seal to fail.
Given the pressures the crank seals are designed to hold at full chat I would expect the bung to be forced out before the seals would fail.
Just hold a bit rag lightly over the exhaust if you want to quieten it for the neighbours while running for a short period.
Edited by 2stroke4stroke
