melba26 Posted February 4, 2016 Report Share Posted February 4, 2016 Hi, I decided to remove the map switch from side of the radiator as it was always wet and I am not sure if it is working or not. On checking the manual and sticker on the bike show different position for the soft (cloud) and hard (sun) settings. The sticker shows depressed for soft which is how I have used the bike. The manual shows depressed with the sun for hard setting. On checking the switch is closed (current flows) when depressed. To be honest I can not tell difference when using the switch but would like to know if depressed is the soft or hard setting hence if I should connect the wires together for soft setting with the switch removed. Thanks in advance for your comments. Melba Quote Link to comment Share on other sites More sharing options...
steve_earle Posted February 4, 2016 Report Share Posted February 4, 2016 Open contact = fast map, Wires joined = soft map. My bike came without a switch so did some research. Most of the other brands of bikes with dual map have open circuit for fast setting. The map switch will do very little on a 250, The Factory 300 there is a difference in the mids. Quote Link to comment Share on other sites More sharing options...
evoalien Posted February 5, 2016 Report Share Posted February 5, 2016 Make shure your not trying to use the headlight switch, thinking its the map switch, They do nothing on the 300 or any other size, kinda usless is my thoughts. I have a 2014 factory 300 riding expert and can hear or feel any difference in the performance of the bike Quote Link to comment Share on other sites More sharing options...
lockie28 Posted February 5, 2016 Report Share Posted February 5, 2016 I never noticed any different until I removed my flywheel weight. Quote Link to comment Share on other sites More sharing options...
pr36 Posted February 9, 2016 Report Share Posted February 9, 2016 Interesting, i have a 250 2t evo 2013 and the map switch plastic box was a bit busted up so i decided to just remove it and join the wires. According to the beta owners manual when the yellow switch is pushed down thats the hard setting for dry, whereas when the switch is in the up position its soft for wet. So i broke the switch open and it looks to me like when the switch is in the hard position the wires are joined. I have since decided to redo it and get a handlebar on/off switch so i can try both settings to see if there is any difference. Quote Link to comment Share on other sites More sharing options...
steve_earle Posted February 9, 2016 Report Share Posted February 9, 2016 The Beta manual is wrong on this, A few mentioned it on here when I was looking for info, I tested and can confirm it, Defiantly Open circuit for fast map. Quote Link to comment Share on other sites More sharing options...
melba26 Posted February 10, 2016 Author Report Share Posted February 10, 2016 Hi, Thanks for replies, Steve is correct and wire disconnected is hard setting, I can feel a very light difference and am going to leave it disconnected. I have black throttle and this seems a good setting for me. Melba Quote Link to comment Share on other sites More sharing options...
sammyd173 Posted February 12, 2016 Report Share Posted February 12, 2016 Hello, 2015 300 4t here. Here's something I just learned today. These switches are sticky. You have to pull up on the switch until you feel a click. This is the fast map when it's all the way up. You may notice the idle pick up. Now press down. You should hear the idle drop a tad. Press the button again for fast/ sunshine map and you likely won't notice anything as the switch will not come all the way up by itself, so give it a little pull. Quote Link to comment Share on other sites More sharing options...
