smiler Posted February 6, 2016 Report Share Posted February 6, 2016 Gas Gas TXT 250 (2000) Service Manual. Hi, Does anyone where I can get a Service manual from? Help - Newbie Cheers Smiler Quote Link to comment Share on other sites More sharing options...
bilks Posted February 6, 2016 Report Share Posted February 6, 2016 (edited) Don't think you will find one unless someone has one that came with there bike, but this might help. . Spark Plug NGKBP5RES, Champion RN11YC, Bosch Platinum WR9DP Trans/Clutch Oil Always 5W30 (Not 10W40), 650cc normal motor oil (Castrol/Penzoil etc). It is not recommended to use synthetic oil. Gasoline 95 Octane minimum. Premix Between 80:1 and 100:1 Brake Fluid DOT 4 is standard. DOT 5 is fine. (All higher numbers mix with lower numbers). This was taken from A Gas Gas site. Also loads info here http://www.trialspartsusa.com/tech.html Edited February 6, 2016 by bilks Quote Link to comment Share on other sites More sharing options...
lowbrow Posted February 6, 2016 Report Share Posted February 6, 2016 Take your pick from these http://www.gasgasmotos.es/en/manuals/6.html The 2000 TXT250 isn't listed but will be the same as the 280 Quote Link to comment Share on other sites More sharing options...
bilks Posted February 6, 2016 Report Share Posted February 6, 2016 There's not one for the 280 either only the parts list for that year. Quote Link to comment Share on other sites More sharing options...
lowbrow Posted February 6, 2016 Report Share Posted February 6, 2016 (edited) There's not one for the 280 either only the parts list for that year. Well spotted. I'm pretty certain they used to be on that page and took it for granted they still were; sorry. Edited February 6, 2016 by lowbrow Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted February 6, 2016 Report Share Posted February 6, 2016 One is on eBay. The manual is the same as the bigger engined bike of the same year. Quote Link to comment Share on other sites More sharing options...
smiler Posted February 6, 2016 Author Report Share Posted February 6, 2016 Thanks Folks Much Appreciated Smiler Quote Link to comment Share on other sites More sharing options...
