Tl 125 Fork Springs
sveson
The hot setup for these bikes is to fit the whole front end from a MT125 or CR125. The fuel tank would need to be reshaped to clear the fork tubes with this change, but it makes the front end suspension and steering much nicer.
Another alternative would be to try and find a set of forks from one of the little Honda trail bikes from the same era that had the same diameter fork tubes (SL125, SL100, XL125) and use the springs out of them
Thank you feetupfun!
I am not planning on changing to much about the bike. If i can just get it a bit stiffer in the front it will be fine. Your suggestion to use springs from for example an XL 125 would be fine for me. The small diameter fork is probably difficult to find progressive springs for.
