Lighter Clutch
neo
You can't really back off the tension on the bolts. They are either tight or loose and fall out which could cause a lot of damage. If you have a heavy clutch try moving the lever along the bar so your finger operates nearer the end of the lever.
Has it got short levers rather than long ones. They don't give as much leverage.
Mark T
