rmack Posted October 15, 2005 Report Share Posted October 15, 2005 need help have just sold my bike yesterday and the new owner has been on with me to say that he cannot pull the clutch lever in it seems to be solid the switch cluster is clear of the lever has any one heard of this problem Quote Link to comment Share on other sites More sharing options...
rmack Posted October 15, 2005 Author Report Share Posted October 15, 2005 have been on the phone with him and he told me that the clutch was draging so he adjusted it yesterday told him to screw the adjuster right out he did still the same ???? Quote Link to comment Share on other sites More sharing options...
rmack Posted October 16, 2005 Author Report Share Posted October 16, 2005 its a 280 pro (02) have had a quick look at it its in at the clutch basket couldnt get the kick start screw out so just let the casing move on the shaft the lever moves ok and the casing moves in and out as soon as u tighten the casing up it is solid again is it possable that the bolt for the clutch bashet has come slack and stopping it ?? Quote Link to comment Share on other sites More sharing options...
markygas Posted October 16, 2005 Report Share Posted October 16, 2005 check all bolts are tight around clutch basket. sounds like problem i had with pro 05. one of the bolts were slack and hitting casing. did you notice any score marks on inside of casing? did you notice any metal filings when you dropped oil? Quote Link to comment Share on other sites More sharing options...
rmack Posted October 17, 2005 Author Report Share Posted October 17, 2005 the oil is clean bike was on its side so no oil would come out am going to work on the bike today ( have all my tools with me ) will let you no how i get on Quote Link to comment Share on other sites More sharing options...
dabs alot Posted October 17, 2005 Report Share Posted October 17, 2005 I'm no "pro" on the Pro, but I think that if the clutch master cylinder piston is not retracting far enough for the hole in the casting to open up it could cause this problem. (Am I correct on this guys??) Have you tried adjusting the piston plunger on the clutch lever? Quote Link to comment Share on other sites More sharing options...
gasserboy Posted October 17, 2005 Report Share Posted October 17, 2005 If it is what went wrong with my 02 i would say its the clutch plates. Change them Quote Link to comment Share on other sites More sharing options...
rmack Posted October 17, 2005 Author Report Share Posted October 17, 2005 sorted it was the clutch basket bolt it had come slack and was stopping the slave cylnder moving new owner very happy now thanks for the help Quote Link to comment Share on other sites More sharing options...
