beta boy Posted January 15, 2004 Report Share Posted January 15, 2004 (edited) i was tightning the bolts on the foot peg brackets on my techno and the bolt snapped clean off ,and the rest is stuck in my frame i need to find fing away of getting it out before my dad finds out cause he just spent Edited February 1, 2004 by beta boy Quote Link to comment Share on other sites More sharing options...
dmx84 Posted January 15, 2004 Report Share Posted January 15, 2004 If it Quote Link to comment Share on other sites More sharing options...
kinell Posted January 15, 2004 Report Share Posted January 15, 2004 Tell him up front and he *should* respect you for it. It will need drilling and rethreading, just done it on my front hub as I nipped up one of the disc bolts and sheared the bugger. Quote Link to comment Share on other sites More sharing options...
clarkp Posted January 15, 2004 Report Share Posted January 15, 2004 Don't try to fix it yourself - if you screw THAT up your dad will REALLY be pi$$ed. Fess up - come clean and help your dad fix it. If he beats your a$$, so be it...take it like a man... lesson learned. At least now you know how much torque it takes to twist off a bolt - file that away in your memory, you'll need it later. Quote Link to comment Share on other sites More sharing options...
Guest sherco dude Posted January 15, 2004 Report Share Posted January 15, 2004 dont know much bout it but will it not need re tapping with a tap set? if it does do not try that yourself i **** my bike up sometimes i just tell me dad then it gets fixed better Quote Link to comment Share on other sites More sharing options...
beta boy Posted January 15, 2004 Author Report Share Posted January 15, 2004 thanks guys dmx84 whats an easy out and how much do they cost oh also i have told my dad what i did he didn't really care he said 'you wont leave it alone intill you brake it will you' i thought he was going to go crazy he also said thats the last time im going to fix that piece of junk ill buy you a knew bike for your birthday so im well pleased maybe ill do it every year so i can get a knew bike Quote Link to comment Share on other sites More sharing options...
Guest sherco dude Posted January 15, 2004 Report Share Posted January 15, 2004 lol wish i could try that one on with me braking stuff ill gat a new bike evry week lol Quote Link to comment Share on other sites More sharing options...
dmx84 Posted January 16, 2004 Report Share Posted January 16, 2004 (edited) Beta Boy, glad your dad understands your situation at hand. I'm glad he Edited January 16, 2004 by DMX84 Quote Link to comment Share on other sites More sharing options...
jaylael Posted January 16, 2004 Report Share Posted January 16, 2004 The standard way this scenrio goes bad is when someone tries to drill it out with a bit that's not perfectly sharp as in at least as good as brand new, then the drill bit wanders off center so bad it gets part way into the threaded frame metal, then the next mistake they make is they put a super hardened "easy out" in the hole which can't turn 'cause it's half in the frame, then they snap the darn thing off in there and it's all wrecked. Ever try to drill a hole through a file? "They" probably ought not to be tryin' that sorta' thing. Quote Link to comment Share on other sites More sharing options...
the artist formerly known as ish Posted January 16, 2004 Report Share Posted January 16, 2004 just done it on my front hub as I nipped up one of the disc bolts and sheared the bugger. FfffffKinell Kinell, if thi gets the entry thi wants, take your bike to John Lampkin and ask for Griffo to set it up for the Scottish for you a week afore thi goes, trust me it el be brass well spent Quote Link to comment Share on other sites More sharing options...
