Where Can I Get Piston Rings
petrg
Unfortunately that is the price they are.
Before buying any rings I would get your bore and piston measured accurately. Often the bore does not wear evenly and the original rings match that. New rings can be a worse fit than the worn old ones. Bore will probably need a light hone - depends on measurement and ring suppliers advice.
May be best getting bore honed and fitting large grade piston kit complete
