cornishtwinspring Posted March 2, 2016 Report Share Posted March 2, 2016 Do any of you good folks know where I can get a new standard spring for my rainbow showas?. Mine is 15yr old and is sagging badly.Tried H&D,& Banyeres and the local dealers. Any ideas greatly appreciated,Thanks. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 2, 2016 Report Share Posted March 2, 2016 Do any of you good folks know where I can get a new standard spring for my rainbow showas?. Mine is 15yr old and is sagging badly.Tried H&D,and Banyeres and the local dealers. Any ideas greatly appreciated,Thanks. Presume same as 4rt so maybe try Honda direct. See what part number is on 4rt web site and google. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 2, 2016 Report Share Posted March 2, 2016 51501-nn4-003 if it helps Quote Link to comment Share on other sites More sharing options...
sportsawyer Posted March 3, 2016 Report Share Posted March 3, 2016 The 315R manual shows the nominal spring length is 384.8mm. The 4RT manual shows the same length, 384.8mm. Neither manual lists the spring rate, so that might be different. But the 4RT spring should fit. 1 Quote Link to comment Share on other sites More sharing options...
cornishtwinspring Posted March 3, 2016 Author Report Share Posted March 3, 2016 Thanks guys,got several avenues to look at. Quote Link to comment Share on other sites More sharing options...
