michel Posted March 2, 2016 Report Share Posted March 2, 2016 249cc 403 Fantic Quote Link to comment Share on other sites More sharing options...
copemech Posted March 3, 2016 Report Share Posted March 3, 2016 I would get it tight! Very tight! 1 Quote Link to comment Share on other sites More sharing options...
samwisemcg Posted March 3, 2016 Report Share Posted March 3, 2016 On 3/3/2016 at 4:05 AM, copemech said: I would get it tight! Very tight! Tight's tight and too tight's f**ked! Quote Link to comment Share on other sites More sharing options...
axulsuv Posted March 5, 2016 Report Share Posted March 5, 2016 These are for a 240 , but you'll get the Idea ... Main gear sprocket Nut 14mm : 70/90Nm Ignition rotor Nut 15 mm : 65/70Nm Head cylinder 4 screw 9mm : 30/35Nm Engine (front) Spindle 10mm : 50/60Nm Engine/Swingin arm spindle 4 screw 8mm : 25/30Nm Gear box covers screw 6mm : 9/11Nm Cluth Nut 16mm : 80/100Nm Shock aborbers 4 screw 8mm : 19/22Nm Front wheel Spindle 15mm : 39/44 Rear wheel Spindle 17mm : 98/117NM Quote Link to comment Share on other sites More sharing options...
