Bantam Trials Build Questions
john b
Hi
Ive covered rim size on a previous post, but thought I would ask the remaing (at the moment) questions in one go
1 - Sprocket size
Its a 4 speed engine - unsure of any internal gearing changes. What the best combination of sprocket sizes ?
Also- chain, 428 ?
2 - Wheel offet
Im about to get new rims built onto bantam hubs
Rear (using a widened swinging arm and engine offset 8mm) - I think needs no offset ?
Front - I think 6mm offset to brake side ?
3 - Chain tensioner
Any advice on best type ?
may think of more !
cheers
John
Hi
1 - Sprocket size
Also- chain, 428 ?
2 - Wheel offet
3 - Chain tensioner
may think of more !
cheers
John
Have you changed the crankshaft sprocket ? you should. 12 tooth crankshaft. 12 tooth gearbox. 60 tooth rear wheel on a 428 chain but some use 420 to help with clearance. I used Whitton hubs which are 17mm offset from brake face front and 34mm from inner sprocket face rear but i dont know if bantam would be same. Chain tensioner depends on where you mount it any aftermarket universal one should do.
Hi John
Ref chain tensioner get one from Jim Pickering (Drayton), it fits at lower rear engine mounting point (actually bracket to frame bolt), it uses a longer bolt has a roller instead of a pad and is well out of the way, they are made to fit Drayton frames but to fit to my modified Bantam frame I just used a thinner nut between roller and bracket and removed a small amount from allen bolt
head one of those jobs where thinking time is more than doing time. I originally used a universal one but it got continually bent
or pad filled with mud and stones.
  • 2 months later...
