glynn Posted March 7, 2016 Report Share Posted March 7, 2016 I ordered some new rear wheel bearings for my txt pro and set about removing the old ones tonight. After some struggle I got the two spacers out to open the bearings up, however I have no way to remove the bearings as theres a centre spacer taking up the gap and is a smaller diameter than the bearing, so I cannot get any edge to knock the bearing outwards. Any help would be greatly apreciated as I want to get back out on the bike Quote Link to comment Share on other sites More sharing options...
jfc Posted March 7, 2016 Report Share Posted March 7, 2016 (edited) Try the one pence piece trick Place the the 1p in the center of the bearing and use an old socket that just slides through the center of the bearing. Hit the socket punching the 1p into the bearing, once the 1p reaches the centre spacer continue knocking the socket until the bottom bearing falls out! Or get a bench press!! Give it a go. Edited March 7, 2016 by jfc 1 Quote Link to comment Share on other sites More sharing options...
glynn Posted March 7, 2016 Author Report Share Posted March 7, 2016 Try the one pence piece trick Place the the 1p in the center of the bearing and use an old socket that just slides through the center of the bearing. Hit the socket punching the 1p into the bearing, once the 1p reaches the centre spacer continue knocking the socket until the bottom bearing falls out! Or get a bench press!! Give it a go. You genius! just gave it a try and worked perfectly! both bearings came out in about 30 seconds, I spent 2 hours tonight finding ways to get them out!! saved me £30 for a wheel bearing tool, this is why I love this community 2 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted March 8, 2016 Report Share Posted March 8, 2016 (edited) Wheel bearing tool would have been my answer, works on all bikes. But good that you managed to get them out Edited March 8, 2016 by crazybond700 1 Quote Link to comment Share on other sites More sharing options...
jsp Posted March 8, 2016 Report Share Posted March 8, 2016 i have one of these which is a god send and not that expensive http://www.ebay.co.uk/itm/SHERCO-BETA-4RT-SCORPA-GAS-GAS-WHEEL-BEARING-DRIFT-BEARING-REMOVAL-TOOL-/161110257936?hash=item2582eb7110:g:t8sAAOxyjNlR0uXM Quote Link to comment Share on other sites More sharing options...
totalshell Posted March 8, 2016 Report Share Posted March 8, 2016 as a yorkshire man though can i still use the penny when its got the bearings out 3 Quote Link to comment Share on other sites More sharing options...
cgunzelman Posted January 22, 2019 Report Share Posted January 22, 2019 Found a video demonstrating the penny trick. Much safer than jim snell's mig welder and slide hammer trick. 1 Quote Link to comment Share on other sites More sharing options...
cascao Posted January 22, 2019 Report Share Posted January 22, 2019 My answer is a expanding mandrel. Fit the mandrel in bearing Put the expanding rod from other side Hit it with a hammer The bearing will exit centered. This is important to not enlarge hub hole To fit new one, you will need a tool to keep spacer centered and apply force centered only on external ring Quote Link to comment Share on other sites More sharing options...
cascao Posted January 22, 2019 Report Share Posted January 22, 2019 Jitsie sell this tools. Yes, it is overkill for who change bearings of one bike 4-5 times in a decade. But your mechanic has to have one...if not, run away. Quote Link to comment Share on other sites More sharing options...
