pudrev3 Posted March 9, 2016 Report Share Posted March 9, 2016 Hey guys I've got a beta Evo 4t 2014 it has a slightly loud ticking , seems worse when it's warm , I had a overheating problem few months ago and I'm thinking it could be damage caused , any advice would be good fellas , cheers ? Quote Link to comment Share on other sites More sharing options...
iridebikes Posted March 9, 2016 Report Share Posted March 9, 2016 Could it be the cam chain loose? Quote Link to comment Share on other sites More sharing options...
spen Posted March 9, 2016 Report Share Posted March 9, 2016 A ticking noise can sometimes be the exhaust to barrel joint starting to leak and 'pop'..... Try nipping it up, not too much, and see if it helps. Go for the simple things before you delve into the (expensive) things..... Quote Link to comment Share on other sites More sharing options...
petert Posted March 10, 2016 Report Share Posted March 10, 2016 A ticking noise can sometimes be the exhaust to barrel joint starting to leak and 'pop'..... Try nipping it up, not too much, and see if it helps. Go for the simple things before you delve into the (expensive) things..... The exhaust is not bolted on these but held in with 2 springs. I would check tappets and camchain adjustment first and go from there. Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted March 10, 2016 Author Report Share Posted March 10, 2016 Ok cheers fellas ?? Quote Link to comment Share on other sites More sharing options...
spen Posted March 10, 2016 Report Share Posted March 10, 2016 The exhaust is not bolted on these but held in with 2 springs. I would check tappets and camchain adjustment first and go from there. Thanks, in that case check the exhaust is seating correctly inside the recess. Quote Link to comment Share on other sites More sharing options...
billyt Posted March 11, 2016 Report Share Posted March 11, 2016 (edited) Very likely to be the valves. Should not need it on a new bike BUT you said the bike got hot. Does the noise frequency increase as you rev the bike? Is it getting hard to start when it is warm? Edited March 11, 2016 by billyt Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted March 11, 2016 Author Report Share Posted March 11, 2016 Yeah it is a nightmare when it's warm and not sure if it gets louder when I Rev it but I've noticed it louder when it's warmed up ? Quote Link to comment Share on other sites More sharing options...
billyt Posted March 11, 2016 Report Share Posted March 11, 2016 (edited) I had the same issue with a Beta 300 4T. The valves needed adjusted. They where adjusted and the ticking, clicking noise went away. Edited March 11, 2016 by billyt Quote Link to comment Share on other sites More sharing options...
heffergm Posted March 11, 2016 Report Share Posted March 11, 2016 Are the valves on the Beta 4t's adjusted with shims? Quote Link to comment Share on other sites More sharing options...
pudrev3 Posted March 11, 2016 Author Report Share Posted March 11, 2016 Not sure about the shims !! But thanks billyt I'll get them to look at it , was it expensive to do ? Quote Link to comment Share on other sites More sharing options...
billyt Posted March 11, 2016 Report Share Posted March 11, 2016 (edited) No shims. Bucket and screw. First thing is to check the clearances. I have the technical manual for the Beta 4T on just the engine. I can send it to you if you like? E-mail me at: williamtraynor@hotmail.com Edited March 11, 2016 by billyt Quote Link to comment Share on other sites More sharing options...
