sando994 Posted March 20, 2016 Report Share Posted March 20, 2016 Hi guys, I've finally got round to start fitting my 2 stage ptb (on my 2015 standard 4rt). I've took the original throttle body off and fitted the new 2 stage. All a very simple process. Now I can't seem to find anywhere to plug in the map switch! Any ideas??? It seems the the only part of the harness which has the same plug, is where I've already plugged in my headlight (under the fuel tank, behind the headstock). Am I missing something??? Or is it a case with the standard model, that I will either have to choose between fitting a headlight OR map switch OR splice into the loom and have both. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted March 20, 2016 Report Share Posted March 20, 2016 I'm not sure if this applies to the latest models, but removing the headlight from the harness was part of the de restriction process on the previous models to allow full power. Quote Link to comment Share on other sites More sharing options...
caddy4u Posted March 20, 2016 Report Share Posted March 20, 2016 Plugs into the headlight plug! When they come from the factory they have a big headlight on for the road, which is taken off (or so i believe). When i bought my Repsol from Craigs, they swapped this for a standard trials light, which also plugged into the headlight plug. When i fitted my PTB i plugged it into the headlight plug and then wired the light into the same plug in parallel. Dead simple. Quote Link to comment Share on other sites More sharing options...
sando994 Posted March 20, 2016 Author Report Share Posted March 20, 2016 Plugs into the headlight plug! When they come from the factory they have a big headlight on for the road, which is taken off (or so i believe). When i bought my Repsol from Craigs, they swapped this for a standard trials light, which also plugged into the headlight plug. When i fitted my PTB i plugged it into the headlight plug and then wired the light into the same plug in parallel. Dead simple.Thanks caddy4u ?? I thought I'd have to splice it in. I'll get on it tomorrow. Then begins the fun of tweaking my own maps Quote Link to comment Share on other sites More sharing options...
