mutley22 Posted March 21, 2016 Report Share Posted March 21, 2016 I'm looking at either a 315r or an Sy250. Montesa prices seem have to gone through the roof so the scorpa is looking tempting but if I'm honest I don't know a lot about either bike. I'm a novice/intermediate rider, mostly ride enduros but like to practice/play on trials. I'm 6'4" and around 85kg. I've had a rev3, txt250 and a sherco 250 in the past but big gaps between each bike so hard to compare. Haven't ridden trials for a while but want to have another go, any recommendations?? Parts availability is something worth considering, I'm looking at between 00 and 05 bikes because limited budget. Thanks Quote Link to comment Share on other sites More sharing options...
utahpete Posted March 22, 2016 Report Share Posted March 22, 2016 I have a TY350 and a Fantic Section, so I'm not the best person to give you advice ... but I have friends with both 315r's and SY250's. I'd choose the Scorpa. Yamaha engine (the years you are looking at), steeper steering angle/tighter full-lock turns. A bit lighter, and just plain nice to ride ... a bit weird-looking though. Quote Link to comment Share on other sites More sharing options...
mazz46 Posted March 22, 2016 Report Share Posted March 22, 2016 Sy awesome bikes 06 onwards even better Quote Link to comment Share on other sites More sharing options...
Cookiemonster Posted March 22, 2016 Report Share Posted March 22, 2016 Had an 1999 315r & currently ride a 2007 SY both great bikes as always buy the best condition bike for your budget You won't go wrong with either bike as long as it's been looked after Spares shouldn't be a problem for either bike Quote Link to comment Share on other sites More sharing options...
ridgrunr Posted March 22, 2016 Report Share Posted March 22, 2016 I own both. A 2008 SY250R and a 2002 315R. Both have great engines, Scorpa Yamaha and Montesa Honda. Both are great bikes, but are different. The Montesa has the smoothest engine at low rpms, The Scorpa hits harder. It think the Montesa is easier to do full lock turns on than the Scorpa, Both handle great, but have different feel as the Scorpa has a linkless rear suspension and the Montesa is linked. The suspension on the Scopra (Marazzoci Aluminum front and Sachs rear) has literally saved my butt more than once, as it just seams to soak up the rough stuff and is much like my 94 Fantic KRoo was, you just point it at something and it will go over it. The Montesa has Showa (iridium) front and rear. I think the Showa suspension is the best ever put on a Trials bike. Smooth like butter. I do think the Montesa is easier to work on, especially carb work, but once you figure out the sequence for doing it, the Scorpa is no big deal either. Both have great plastic. Scorpa steel frame, Mmontesa auminum. Both have he same control components. Both of my bikes have original plastic, and although they are scratched up some both rear fenders have bent almost double and neither broke, but I removed the rear mount screws and replaced them with Zip ties that will break before the rear fender does, The Montesa is the easier starter, two kicks cold, one warm. The Scorpa is three kicks cold, one warm. The Scorpa uses that funky TK carb which can be a little hard to find jets for. Both have been bullet proof. My son prefers the Montesa. He rides Advanced and can hop the thing (front and rear) all over. I ride Intermediate and prefer the Scorpa, but I'm 61. We've ridden them at a monthly Trials event for almost the entire time we've had them and both have been across the Five Miles of Hell half a dozen times. The Montesa has a little bigger fuel tank, as in in capacity, and will go a little farther on a tank of gas. The Scorpa has the better clutch. No drag at all. I run Maxima lite 75 wt oil in it. The Montesa has a little more drag, sort of like a Beta. I run Valvoline ATF in the red bottle in it and it has less drag than it did with the Maxima. The Montesa clutch will squeal a little once in awhile when you are really playing it hard at low RPMS trying to get max power. It's something they all do. The Montesa is a little more old school in design, with the forks raked out slightly more than the Scorpa, but my son says it makes it more stable in the turns. The Scorpa is a little steeper. Is one better than the other, I guess it depends who you talk to, but both have been great bikes. Don't know if this helps or not. I don't think you can go wrong with either. 3 Quote Link to comment Share on other sites More sharing options...
mutley22 Posted March 22, 2016 Author Report Share Posted March 22, 2016 Thanks for the replies. It's looking like the scorpa is the likely choice, if I'm honest I was hoping for the Montesa but the price is too high, 03 models advertised for nearly £3000!! Is there any difference between scorpa year models? Which would be the best to go for ideally? Quote Link to comment Share on other sites More sharing options...
utahpete Posted March 23, 2016 Report Share Posted March 23, 2016 2008 and earlier have Yamaha engines ... 2009 ? and beyond have Sherco engines. Hope this is right, but if not, responses should correct any mistakes. Quote Link to comment Share on other sites More sharing options...
coop650 Posted March 25, 2016 Report Share Posted March 25, 2016 (edited) I have a 2005 SY250 with the Yamaha engine and I really like it. It will be a good bike to beat up for a year or two while I learn some bike control before I buy a new bike. Edit: I meant to also post the guy I bought from is a friend and he replaced with with a 4RT. I find the 4RT much harder to ride, but I can't put my finger on it. Probably something to do with my noob level of skills. Edited March 25, 2016 by coop650 Quote Link to comment Share on other sites More sharing options...
mutley22 Posted April 10, 2016 Author Report Share Posted April 10, 2016 Thanks for the replies! I ended buying an 04 scorpa, took it out for a quick ride yesterday, it's very different to the sherco I used to have! The power delivery is super smooth. Is it possible to adjust the power? Will give it a few more rides but I might like it a bit more snappy. I do need to replace the fork seals, does anyone recommend a parts supplier in the uk? Thanks again Quote Link to comment Share on other sites More sharing options...
ridgrunr Posted May 6, 2016 Report Share Posted May 6, 2016 Might have a slow throttle tube. You can put a fast tube on there that will quicken it up some. I think the slow one is black and the fast one is white. Quote Link to comment Share on other sites More sharing options...
fastbelly Posted October 28, 2016 Report Share Posted October 28, 2016 The flywheel can be modified to reduce its weight. however, ride it in the winter first to discover the best thing about that motor. They are amazing in the mud. Quote Link to comment Share on other sites More sharing options...
bigmike1961 Posted November 26, 2016 Report Share Posted November 26, 2016 You can adjust the timing I believe but can't find the link - think it was on the Hell Team website but can't see it now. Retarded was for mud and advanced gave the engine more snap for rocks. British ones came set for mud I believe. Quote Link to comment Share on other sites More sharing options...
